Author Topic: Books on Verilog/VHDL  (Read 17132 times)
Offline miguelvp
Re: Books on Verilog/VHDL
« Reply #25 on: May 08, 2014, 02:20:55 am »
It's been done, google P.A.C.E "Programmable Arcade Circuit Emulation"
But their forum is broken at the moment.  I'm porting it to two new dev boards at the moment.
ooh neat.  can you PM me your progress? I'd rather not derail this thread further...
PM sent with as much info as I could fit in there :)
Offline maxslug
    • Nikon Hacker
« Reply #26 on: May 08, 2014, 04:21:30 am »
My $0.02.   You see a lot of copies of "Verilog HDL" by Palnitkar on people's desks.  I have a copy myself.   It teaches you the syntax of verilog 2000, but it otherwise is awful.
I recently got this one  : http://www.amazon.com/dp/1482593335/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2QB68NXFDIJOH&coliid=I32COIDXH3KYX4  and think it's great.   It teaches you digital design constructs at the same time as teaching you HDL.  I just leant it to a coworker who wanted to learn Verilog.
As for VHDL vs Verilog :  I've learned both, but note that there are an order of magnitude more job listings with Verilog than VHDL.
That would sway me into the Verilog camp unless I was going to work in a VHDL shop or on a specific project.
-m
Chip Designer and Janitor of https://nikonhacker.com
Offline miguelvp
« Reply #27 on: May 08, 2014, 04:31:39 am »
I've heard about this getting popular but not sure if it is actually getting popular or if it's just hype:
http://en.wikipedia.org/wiki/SystemVerilog
It's supposed to be as easy as Verilog but with VHDL but I can't afford the Cadence, Mentor or Synopsys toolchains.
Object oriented Verilog ala Java?
Offline maxslug
    • Nikon Hacker
« Reply #28 on: May 08, 2014, 04:50:12 am »
SystemVerilog has gained a lot of popularity in test bench code, but not so much in synthesizable code.    I have used it for both with mixed success.    SystemVerilog+UVM for verification (test-bench) seems to be a winning ticket.    For synthesizable code you have to be very careful about what your target software (Synopsys Design Compiler, Cadence RC, Xilinx ISE/Vivado, Altera Quartus, etc) at your specific version supports.    In general the support for different syntax and constructs tends to be "guess and check".
That said, it does fix a lot of the tricky problems in verilog with things like 'unique case' and 'always_ff'.    If you want to play with it (or VHDL or Verilog), I would suggest getting the free WebPack version of Xilinx Vivado or ISE, and playing around there.  I think that comes with a simulator.
-m
Offline jeremy
« Reply #29 on: July 13, 2014, 08:15:09 am »
-m
Does anyone know where I can get this book in electronic format? I'm happy to pay for it, but I'm just not in a position to have many physical books at the moment.
Offline Sailor
« Reply #30 on: July 14, 2014, 12:07:05 pm »
I can't help you with that book, it's pretty new (2013), although I think a free kindle version is available from the author's site.  (EDIT: Sorry 'bout that - no, it looks like it wasn't legit, and has been removed.)
There are a bunch of other good books on the web if you look hard enough e.g.
Digital Systems Design with FPGAs and CPLDs  Ian Grout 2008 Elsevier
Advanced FPGA Design Architecture, Implementation, and Optimization Steve Kilts 2007
Digital VLSI Design with Verilog John Williams 2008
FPGA PROTOTYPING BY VERILOG EXAMPLES Xilinx SpartanTM-3 Version Pong P. Chu 2008
Good hunting.
« Last Edit: July 14, 2014, 12:21:47 pm by Sailor »
Offline jeremy
« Reply #31 on: July 14, 2014, 12:16:06 pm »
I can't help you with that book, it's pretty new (2014), although I think a free kindle version is available from the author's site. There are a bunch of other good books on the web if you look hard enough e.g.
Good hunting.
I had a look on the authors site but it doesn't appear to be there, dang. I have plenty of books on verilog, but I am interested in the axi information. Perhaps I will try to get the dead tree version
Offline Sailor
« Reply #32 on: July 14, 2014, 12:26:24 pm »
I guess you were posting while I was editing ;D
axi ???
Offline jeremy
« Reply #33 on: July 14, 2014, 01:47:57 pm »
http://www.arm.com/products/system-ip/amba/amba-open-specifications.php
AXI is the bus used by the Xilinx zynq to connect the FPGA fabric to the hard arm cores. I've been trying to find some good, practical information on using the Linux kernel/fabric interconnect which doesn't involve piecing a million little bits of information together from the internet.
Suggestions (especially verilog ones) are welcome  ;D
« Last Edit: July 14, 2014, 01:51:03 pm by jeremy »
Offline legacy
« Reply #34 on: July 14, 2014, 03:37:15 pm »
i can provide you this book in pdf, for free, also the VHDL version is possible.
in case send a PM to me
Offline legacy
« Reply #35 on: July 14, 2014, 05:52:07 pm »
have you also seen this book ?
Offline Sailor
« Reply #36 on: July 14, 2014, 11:50:04 pm »
Yes, they also teamed up with a third author for this later version:
Rapid prototyping of digital systems - Quartus II edition (2006)
and the same three also did:
Rapid Prototyping of Digital Systems - SOPC Edition (2008)
All three are available on the web.
Offline miguelvp
« Reply #37 on: July 15, 2014, 12:03:20 am »
Too bad that Altera phased out SOPC and now uses QSys, although is similar enough to be relevant but the details might confuse first time users.
Offline legacy
« Reply #38 on: July 15, 2014, 08:54:36 am »
about good books, i was suggested about this one
Digital Design and Computer Architecture: From Gates to Processors
David Harris, Sarah Harris
it is available in Kindle format for about $50 USD
Offline bwat
    • My website
« Reply #39 on: July 15, 2014, 09:12:27 am »
Which prompts the question: "why didn't you read the book and build your own MIPS core instead of all the hassle you've gone through the last month or so?" They've even got their MIPS source online for you to download.
« Last Edit: July 15, 2014, 09:14:45 am by bwat »
"Who said that you should improve programming skills only at the workplace? Is the workplace even suitable for cultural improvement of any kind?" - Christophe Thibaut
"People who are really serious about software should make their own hardware." - Alan Kay
Offline legacy
« Reply #40 on: July 15, 2014, 09:47:02 am »
the companion material provided online with this book is MIPS mono cycle, practically a toy that can be ONLY simulated
« Last Edit: August 07, 2014, 02:20:21 am by legacy »
Offline bwat
    • My website
« Reply #41 on: July 15, 2014, 09:52:57 am »
The book gives you everything you need to build and understand a MIPS implementation!
Offline legacy
« Reply #42 on: July 15, 2014, 10:09:39 am »
I find it very helpful to learn from other people's mistakes  >:D
me, too  >:D
Offline legacy
« Reply #43 on: July 20, 2014, 04:36:17 pm »
I have found this book this book(1), and it seems very very good
(1) Digital Logic and Microprocessor Design with VHDL by Enoch O. Hwang
Offline legacy
« Reply #44 on: August 08, 2014, 12:47:25 am »
also i have bought this book by Peter J. Ashenden and it's excellent: Digital Design (VHDL): An Embedded Systems Approach Using VHDL
if you prefer, there is the Verilog version: Digital Design (VHDL): An Embedded Systems Approach Using Verilog
Offline UnixonTopic starter
« Reply #45 on: August 18, 2014, 08:47:17 pm »
Quickly browsed through chapters... this book is awesome.
https://www.uop.edu.jo/download/research/members/Digital_Design_and_Computer_Architecture.pdf
There was another one on the server
https://www.uop.edu.jo/download/research/members/Digital_Design_-_A_Comprehensive_Guide_to_Digital_Electronics_and_Computer_System_Architecture_20.pdf
Probably worth reading as well.
« Last Edit: August 18, 2014, 08:53:36 pm by Unixon »
« Reply #46 on: August 18, 2014, 09:12:32 pm »
Yes, this one also looks very interesting, detailed explanation of different circuits.
http://serenitystreetnews.com/HERSTORY%20CRAMNOTES/5dterra%20NOTES%20AUDIO%20VIDEO/ebooks/ebooks/Digital%20Logic%20And%20Microprocessor%20Design%20With%20VHDL%20by%20Enoch%20O%5B1%5D.%20Hwang.pdf
« Reply #47 on: August 18, 2014, 09:20:48 pm »
Recently I've got both of these in paper versions. Mostly aimed at beginners, starts with elementary things, ramps up to a custom 8-bit CPU, doesn't go very deep in explaining complex stuff. The other book mentioned before "Digital Design and Computer Architecture: From Gates to Processors" by  David Harris, Sarah Harris is much more detailed. Nevertheless, I would prefer to have both of them, because topic coverage and explanation depth differs from one place to another.
Offline jeremy
« Reply #48 on: August 19, 2014, 12:42:58 am »
Yes, the Harris book is very good. Especially the new edition, which covers SystemVerilog instead of just Verilog.
