Author Topic: Bought an Altera CPLD dev board, where to start?  (Read 11883 times)
Offline miguelvp
Re: Bought an Altera CPLD dev board, where to start?
« Reply #25 on: July 09, 2014, 07:12:19 pm »
Well, the thing is with CPLDs is that they shouldnt be the main attraction of a project. They are almost always a companion device, for a MCU or an FPGA. Unless you make something very simple.
Altera's MAX V is really an FPGA but with non-volatile configuration but only up to 2200 LE for around $20 per chip with 7ns gate switching speed, but it seems like they are going to blur the line more with their MAX 10, but no details until Q4 2014.
You can request early access (probably under NDA):
http://www.altera.com/devices/fpga/max-10/max-10-index.html
But they do talk about running Nios II, and they are actually calling it a non-volatile FPGA instead of CPLD.
Last one to get to revision 10 is the Cyclone, I wonder if they are planing to replace the Cyclone with the Max or if they will over a 10 series Cyclone that is volatile.
Offline ScottyAU
    • ScottyAU
« Reply #26 on: July 09, 2014, 09:12:09 pm »
Bingo600 - that link from Aliexpress is for 2 - but still not quite as cheap as your ebay link :)
http://www.aliexpress.com/item/Altera-MAX-II-EPM240-CPLD-Development-Board-Learning-Breadboard/1295523986.html
Offline amyk
« Reply #27 on: July 10, 2014, 01:04:58 pm »
Here's an interesting project you can do with a moderately-sized FPGA - implement an SoC containing a CPU, a GPU, and an audio generator; and then write the software for it too: http://www.linusakesson.net/scene/parallelogram/
