Thanks for that. I'd actually already obtained the programmer from FTDI and flashed the new XML, that part seems to work fine, but when I get into the Diamond Programmer, I just keep getting the latter part of this:
<paste start>
WARNING - A new firmware version for this cable is available. Please visit the Lattice website and download and install the latest cable firmware.
Lattice VM Drivers detected (HW-DLN-3C (Parallel), HW-USBN-2B (FTDI))
Programmer device database loaded
INFO - Scanning USB2 Port FTUSB-0...
ERROR - Scan Failed - Creating Blank Programmer Project.
ERROR - Failed to Open FTDI USB port. Make sure to select the right cable type.
If you have not installed the FTDI Windows USB Driver, follow the instructions in the Programmer Help topic:
"Installing/Uninstalling Parallel Port Driver and USB Driver".
If you have installed the driver, if you recently plugged in the cable, please wait a few seconds and try again.
This will give the operating system time to recognize the cable.
<paste end>
... with that last bit about failing to open the port repeating for every action I attempt. It feels like a driver problem, but the FTDI utility doesn't seem to have a problem, so I'm at a loss.
I notice I'm a couple Diamond versions behind so I'm downloading the latest (3.5) right now. I'll post an update if anything changes. Thanks for the advice.
