I thought that I had a Z80A but I don't.
RS only do http://uk.rs-online.com/web/p/microcontrollers/6259078/
Would this drop straight into a circuit designed for a Z80A running at 4MHz ?
Thanks
In general I would expect that 10MHz part to be a drop in replacement for the 4MHz part, however there will be a shorter time between the reference clock edge for a given transition on the control lines/bus and that transition actually happening.
Whether this means the faster part won't work will depend on the system that you plug it into. If you have flip-flops triggered on clock edges as well as control signals it might be worth reviewing the timing but you'd be pretty unlucky to have any issues.
I'd just plug it in and see.
