Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Microcontrollers
Can anyone share HX711 c driver code
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Can anyone share HX711 c driver code (Read 3927 times)
muthukural001
Regular Contributor
Country:
on:
April 23, 2018, 07:24:41 am »
Hello All,
I am using HX711 as part of the project. For I know, it is not based on neither I2C nor SPI. All the sample codes are available in Arduino. If anyone had worked with HX711, can you share the sample code ?
Thanks,
Muthu
Logged
agehall
Frequent Contributor
Country:
Re: Can anyone share HX711 c driver code
Reply #1 on:
April 23, 2018, 08:05:55 am »
For what platform? If Arduino is not good enough, you need to specify what you want.
Most people would simply read the Arduino code to understand how to use it if the datasheet doesn't tell you and then adopt the code to whatever platform you are using. Arduino code is no magic, it is pretty much standard C/C++ code.
Logged
nugglix
muthukural001
Regular Contributor
Country:
Reply #2 on:
April 23, 2018, 09:02:55 am »
Sorry for not Mentioning. I need it in C language. Well, Arduino code for HX711 looks standard library and I don't know and can't find what is inside.
Logged
daveshah
Supporter
Country:
Reply #3 on:
April 23, 2018, 09:11:46 am »
There seems to be reference C code in the datasheet on page 8.
https://www.mouser.com/ds/2/813/hx711_english-1022875.pdf
Logged
westfw
Super Contributor
Country:
Reply #4 on:
April 23, 2018, 09:34:56 am »
You don't find this understandable?
https://github.com/aguegu/ardulibs/blob/master/hx711/hx711.cpp
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Microcontrollers
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
