Hi All,
For a while now I have been wanting to progress myself beyond Arduino and begin to learn more about microcontrollers and become more capable, I need to home my skills.
Problem is, I know Arduino and I feel I keep diving off into the deep end, I have spent quite a bit of money on devkits for microcontrollers I think may be too complex for me.
Now, I have stepped back a bit and I want to start again into microcontrollers, I feel Arduino has just kinda messed it up, making it too simple to the point I feel lazy not understanding or doing anything beyond simple Arduino 'stuff'.
I want to try get into protocols, timing and so on, controlling Switching systems (Transformer drivers) and communications and busses, get involved with motor drivers and all sorts.
The real question I have... Where should I truly start and how? Tutorials etc. I have been kidding myself into thinking 'I know all this' for too long. When I don't really.
What I have already:
TI Launchpad Tiva C Series.
A Huge pile of Arduino products (Nanos, Megas and Unos)
Cypress CY8CKIT (the USB stick one)
Freescale FRDM-KL43Z
SAM4S-EK2 Dev Board
What would you recommend I get or start with (I don't mind buying more if it is worth while...)
What tutorials can I look at.
I really appreciate any response or advice, feedback or thoughts!
Take a look at Astrobe :
https://youtu.be/qmSqhAG_ea0Astrobe targets the majority of the NXP's LPCxxx series boards. Plus has a really cool RISC5 experimental FPGA core ( a 'soft processor core' much like a PicoBlaze or MicroBlaze by based upon ProjectOberon.com). Google 'Microblaze'. It is much less intimidating to work with FPGA's than you think. Very simple actually and allows you to peek at the actual wires and gates of the 'soft processor'.
Now take a look at the compiled binary size from the compile debug panel from the project in the video:
Oberon for Cortex-M3 Compiler v5.3.0
compiling DisplayDemo
code generated = 972 bytes, data = 0 bytes
Now give this 300 lines of code a good study and you have the ability to do CAD drawing on an MCU!! And do all this in
UNDER 1 KB.
This is the core drawing library to what I believe is the same demo in the video.
The complete program, including the CAD data for this project is a mere 17KB.
MODULE LCDST756R;
Example ARM Cortex-M3 Oberon Module
Description:
Sitronix ST756R LCD Controller Driver
Target:
mbed systems
Tested on:
ARM mbed Application Board with a Newhaven C12832A1Z 128 x 32 LCD display
Reference:
Sitronix ST756R DataSheet Ver 1.5 (10 Mar 2006).
(c) 2013-2014 CFB Software
http://www.astrobe.com
IMPORT Timer, MCU, ResData, SPI, SYSTEM;
CONST
Black* = 0;
White* = 1;
MaxX* = 127;
MaxY* = 31;
FontWidth = 6;
FontHeight = 8;
Cols* = (MaxX + 1) DIV FontWidth;
Rows* = (MaxY + 1) DIV FontHeight;
Pages* = (MaxY + 1) DIV 8;
A0 = {6}; (* P0.6 = mbed P8 *)
CS = {18}; (* P0.18 = mbed P11 *)
Reset = {8}; (* P0.8 = mbed P6 *)
TYPE
(* Each bit represents a pixel on the screen *)
(* Each page can be refreshed invidually *)
BitMap = ARRAY MaxX + 1 OF SET;
(* 6 x 8 pixels *)
FontPattern = ARRAY FontWidth OF BYTE;
VAR
font: ResData.Resource;
fontPattern: FontPattern;
(* In-memory representation of the screen *)
bitMap0, bitMap: BitMap;
PROCEDURE LoadFont*(name: ARRAY OF CHAR): BOOLEAN;
BEGIN
ResData.Open(font, name);
RETURN ResData.Size(font) > 0
END LoadFont;
(* Store the font data for a character in a 2-D pixel array *)
PROCEDURE CharToFontPattern(ch: CHAR; VAR fontPattern: FontPattern);
VAR
i, index: INTEGER;
BEGIN
IF (ORD(ch) < ORD(" ")) OR (ORD(ch) > ORD("~")) THEN ch := "." END;
index := (ORD(ch) - ORD(" ")) * 8;
FOR i := 0 TO FontWidth - 1 DO
ResData.GetByte(font, index + i, fontPattern[i]);
END
END CharToFontPattern;
PROCEDURE SendData(data: INTEGER);
BEGIN
SYSTEM.PUT(MCU.FIO0SET, A0);
SYSTEM.PUT(MCU.FIO0CLR, CS);
SPI.SendData(data);
SYSTEM.PUT(MCU.FIO0SET, CS);
END SendData;
PROCEDURE SendCommand(data: INTEGER);
BEGIN
SYSTEM.PUT(MCU.FIO0CLR, A0);
SPI.SendData(data);
END SendCommand;
PROCEDURE SetColumnAddr(x: INTEGER);
CONST
ColumnAddrLo = 000H;
ColumnAddrHi = 010H;
BEGIN
SendCommand(ColumnAddrLo + x MOD 16);
SendCommand(ColumnAddrHi + x DIV 16)
END SetColumnAddr;
PROCEDURE SetPageAddr(n: INTEGER);
CONST
PageAddrSet = 0B0H;
BEGIN
SendCommand(PageAddrSet + n)
END SetPageAddr;
PROCEDURE* DrawDot*(colour, x, y: INTEGER);
BEGIN
IF (x <= MaxX) & (y <= MaxY) & (x >= 0) & (y >= 0) THEN
IF colour = Black THEN
bitMap[x] := bitMap[x] + {y}
ELSE
bitMap[x] := bitMap[x] - {y}
END
END
END DrawDot;
PROCEDURE* DrawVerticalLine*(colour: INTEGER; x, y1, y2: INTEGER);
VAR
yBits: SET;
BEGIN
IF (x >= 0) & (y1 >= 0) & (y2 >= y1) & (y2 <= MaxY) THEN
yBits := {y1..y2};
bitMap[x] := bitMap[x] + yBits
ELSE
bitMap[x] := bitMap[x] - yBits
END
END
END DrawVerticalLine;
PROCEDURE* FillRectangle*(colour, x1, y1, x2, y2: INTEGER);
VAR
x: INTEGER;
yBits: SET;
BEGIN
IF (x >= 0) & (x2 > x1) & (x2 <= MaxX) & (y1 >= 0) & (y2 >= y1) & (y2 <= MaxY) THEN
yBits := {y1..y2};
FOR x := x1 TO x2 DO bitMap[x] := bitMap[x] + yBits END
ELSE
FOR x := x1 TO x2 DO bitMap[x] := bitMap[x] - yBits END
END
END
END FillRectangle;
PROCEDURE* DrawFontChar(fontPattern: FontPattern; col, row: INTEGER);
VAR
i, x, adr, fontAdr: INTEGER;
fontData: BYTE;
BEGIN
ASSERT((col >= 0) & (col < Cols) & (row >= 0) & (row < Rows), 100);
x := (col * FontWidth);
adr := SYSTEM.ADR(bitMap[x]) + row;
fontAdr := SYSTEM.ADR(fontPattern);
SYSTEM.GET(fontAdr, fontData, 1);
SYSTEM.PUT(adr, fontData, 4)
END
END DrawFontChar;
PROCEDURE DrawChar*(colour: INTEGER; ch: CHAR; col, row: INTEGER);
VAR
BEGIN
CharToFontPattern(ch, fontPattern);
DrawFontChar(fontPattern, col, row)
END DrawChar;
PROCEDURE Refresh*();
(* Only write the pixel columns that have changed since the last refresh *)
VAR
pageNo, x, adr0, adr: INTEGER;
data0, data: BYTE;
col: INTEGER;
BEGIN
FOR pageNo := 0 TO Pages - 1 DO
SetPageAddr(pageNo);
col := -1;
adr0 := SYSTEM.ADR(bitMap0) + pageNo;
adr := SYSTEM.ADR(bitMap) + pageNo;
FOR x := 0 TO MaxX DO
SYSTEM.GET(adr0, data0, 4);
SYSTEM.GET(adr, data, 4);
IF data # data0 THEN
IF col # x THEN
SetColumnAddr(x);
col := x
END;
SendData(data);
INC(col)
END
END
END;
bitMap0 := bitMap
END Refresh;
PROCEDURE* ClearScreen*(colour: INTEGER);
VAR
x: INTEGER;
BEGIN
IF colour = White THEN
bitMap[x] := {}
END
ELSE
bitMap[x] := {0..31}
END
END
END ClearScreen;
PROCEDURE* ConfigureSPI1Pins;
VAR
s: SET;
BEGIN
(* SPI1 *)
(* Setup SCK1, SSEL1, MISO1, MOSI1, no SSEL *)
(* PS0 bits 15:14 12:13 17:16, 19:18 := 10B *)
SYSTEM.GET(MCU.PINSEL0, s);
s := s + {15, 17, 19} - {14, 16, 18};
SYSTEM.PUT(MCU.PINSEL0, s)
END ConfigureSPI1Pins;
PROCEDURE* ConfigureGPIOPins;
VAR
s: SET;
BEGIN
(* P0.6, P0.8 are GPIO ports *)
s := s - {12, 13, 16, 17};
SYSTEM.PUT(MCU.PINSEL0, s);
(* P0.18 is GPIO port *)
SYSTEM.GET(MCU.PINSEL1, s);
s := s - {4, 5};
SYSTEM.PUT(MCU.PINSEL1, s);
(* P0.6, 0.8 and 0.18 are outputs *)
SYSTEM.GET(MCU.FIO0DIR, s);
SYSTEM.PUT(MCU.FIO0DIR, s + A0 + CS + Reset)
END ConfigureGPIOPins;
PROCEDURE Init*;
CONST
nBits = 8;
BEGIN
SPI.Init(SPI.SPI1, nBits, ConfigureSPI1Pins);
ConfigureGPIOPins();
SYSTEM.PUT(MCU.FIO0CLR, Reset);
Timer.uSecDelay(100);
SYSTEM.PUT(MCU.FIO0SET, Reset);
SendCommand(0AEH); (* Display off *)
SendCommand(0A2H); (* Bias voltage *)
SendCommand(0A0H); (* ADC Normal *)
SendCommand(0C8H); (* COM Scan normal *)
SendCommand(022H); (* Resistor ratio *)
SendCommand(02FH); (* Power on *)
SendCommand(040H); (* Display start line 0 *)
SendCommand(081H); (* Set contrast *)
SendCommand(017H);
SendCommand(0A6H); (* Display normal *)
ClearScreen(Black);
bitMap0 := bitMap;
ClearScreen(White);
Refresh();
SendCommand(0AFH); (* DisplayOn *);
END Init;
END LCDST756R.
