Author Topic: CFB amplifiers as comparators, advice?  (Read 1169 times)
Offline BoscoeTopic starter
« on: June 15, 2018, 08:28:17 pm »
Hi all,
I'm trying to use an EL5166 as a CCD clock driver running at 28MHz which needs a voltage swing from -4.5 to 1.5V and a rise time of 3ns or less. I selected this op amp for it's 6000V/us slew rate and high output current which are the limits I've hit before. However I get a small 200mVpp highly distorted output waveform at any frequency by holding the inverting input at 1.5V and applying a 3.3V square wave signal from the FPGA into the non inverting input. I'm using a +/-4V supply for this test.
I'd appreciate some advice for driving CCD clocks. Here are the requirements:
- High slew rate needs 8V in 4ns rise and fall.
- Maximum 10V working voltage.
- Current output of at least 100mA peak.
This means a lot of high speed voltage comparators are out due to working at a maximum of 5.5V, and MOSFET gate drivers are too slow. Buffered op amps are difficult to get the speed and limit cross conduction.
Thanks!
Offline nctnico
Re: CFB amplifiers as comparators, advice?
« Reply #1 on: June 15, 2018, 09:34:20 pm »
Start by not overdriving the input of the opamp. In other words: set the amplification of the OPAMP and feed it a signal with the appropriate input level. Rule number one of using opamps: never use an opamp as a comparator!
Online David Hess
  • DavidH
« Reply #2 on: June 16, 2018, 10:10:56 am »
I looked up an old Tektronix CCD design (7D20) and they used a complementary pair of RF bipolar transistors in an open loop class-b common emitter amplifier to do the level shift from logic levels.
« Reply #3 on: June 16, 2018, 10:57:18 am »
I've never heard of this. Why is this the case?
« Reply #4 on: June 16, 2018, 10:58:27 am »
Thanks, I'll get on the simulator and try this out.
Online David Hess
  • DavidH
« Reply #5 on: June 16, 2018, 12:26:05 pm »
Operational amplifiers just make poor comparators.  They are not designed to operate with their internal nodes in saturation and frequency compensation limits their speed.
I would not necessary copy what Tektronix did exactly.  I linked it just to give an idea of what has been done in the past and I think a saturated level shifter is the way to go even if that means a discrete output stage.
A linear amplifier with the output characteristics you specified is feasible but if it also has to operate in saturation, then the linear operation part might as well be skipped.
