im trying to connect a FPGA (Altera DE0) via i2c to a mikrocontroller (Arduino, RaspberryPi, etc ...) using copencores i2c-core.
I programmed already the toplevel for the i2c-core with VHDL to write from the FPGA via the i2c bus to the mikrocontroller.
(FPGA is the master and the mikrocontroller on the other side the slave)
The problem: I cant see any signal on the clock line and also on the data line with the oscilloscope.
Im 100% sure that the pinassignment ist correct.
Can someone look over my code to detect the problem?
I have no idea what the problem is.
Im new to VDHL maybe I did something wrong.
The code I programmed: i2c_controller_top.vhd and writeDummy.vhd
Thanks
