Hello,
I have used this code for a function generator project utilizing the AD9851 module and a rotary encoder and It works flawlessly using the UNO,
Now that I want to build a small plastic box for it and fit everything in I want to use the Smaller Nano for this project and to be honest I have very very little Arduino programming knowledge so any help is highly appreciated
The original Uno code is
Main code by Richard Visokey AD7C -
www.ad7c.comRevision 2.0 - November 6th, 2013... ever so slight revision by VK8BN for AD9851 chip Feb 24 2014
// Include the library code
#include <LiquidCrystal.h>
#include <rotary.h>
#include <EEPROM.h>
//Setup some items
#define W_CLK 8 // Pin 8 - connect to AD9851 module word load clock pin (CLK)
#define FQ_UD 9 // Pin 9 - connect to freq update pin (FQ)
#define DATA 10 // Pin 10 - connect to serial data load pin (DATA)
#define RESET 11 // Pin 11 - connect to reset pin (RST)
#define pulseHigh(pin) {digitalWrite(pin, HIGH); digitalWrite(pin, LOW); }
Rotary r = Rotary(2,3); // sets the pins the rotary encoder uses. Must be interrupt pins.
LiquidCrystal lcd(12, 13, 7, 6, 5, 4); // I used an odd pin combination because I need pin 2 and 3 for the interrupts.
int_fast32_t rx=1000000; // Starting frequency of VFO =============================================================================( )
int_fast32_t rx2=1; // variable to hold the updated frequency
int_fast32_t increment = 1000000; // starting VFO update increment in HZ.
int buttonstate = 0;
String hertz = "10 Hz";
int hertzPosition = 5;
byte ones,tens,hundreds,thousands,tenthousands,hundredthousands,millions ; //Placeholders
String freq; // string to hold the frequency
int_fast32_t timepassed = millis(); // int to hold the arduino miilis since startup
int memstatus = 1; // value to notify if memory is current or old. 0=old, 1=current.
int ForceFreq = 1; // Change this to 0 after you upload and run a working sketch to activate the EEPROM memory. YOU MUST PUT THIS BACK TO 0 AND UPLOAD THE SKETCH AGAIN AFTER STARTING FREQUENCY IS SET!
void setup() {
pinMode(A0,INPUT); // Connect to a button that goes to GND on push
digitalWrite(A0,HIGH);
lcd.begin(16, 2);
PCICR |= (1 << PCIE2);
PCMSK2 |= (1 << PCINT18) | (1 << PCINT19);
sei();
pinMode(FQ_UD, OUTPUT);
pinMode(W_CLK, OUTPUT);
pinMode(DATA, OUTPUT);
pinMode(RESET, OUTPUT);
pulseHigh(RESET);
pulseHigh(W_CLK);
pulseHigh(FQ_UD); // this pulse enables serial mode on the AD9851 - see datasheet
lcd.setCursor(hertzPosition,1);
lcd.print(hertz);
// Load the stored frequency
if (ForceFreq == 0) {
freq = String(EEPROM.read(0))+String(EEPROM.read(1))+String(EEPROM.read(2))+String(EEPROM.read(3))+String(EEPROM.read(4))+String(EEPROM.read(5))+String(EEPROM.read(6));
rx = freq.toInt();
void loop() {
if (rx != rx2){
showFreq();
sendFrequency(rx);
rx2 = rx;
buttonstate = digitalRead(A0);
if(buttonstate == LOW) {
setincrement();
// Write the frequency to memory if not stored and 2 seconds have passed since the last frequency change.
if(memstatus == 0){
if(timepassed+2000 < millis()){
storeMEM();
ISR(PCINT2_vect) {
unsigned char result = r.process();
if (result) {
if (result == DIR_CW){rx=rx+increment;}
else {rx=rx-increment;};
if (rx >=70000000){rx=rx2;}; // UPPER VFO LIMIT
if (rx <=1){rx=rx2;}; // LOWER VFO LIMIT
// frequency calc from datasheet page 8 = <sys clock> * <frequency tuning word>/2^32
void sendFrequency(double frequency) {
int32_t freq = frequency * 6442560000./180000000; // note 180 MHz clock on 9851. also note slight adjustment of this can be made to correct for frequency error of onboard crystal
for (int b=0; b<4; b++, freq>>=8) {
tfr_byte(freq & 0xFF);
tfr_byte(0x001); // Final control byte, LSB 1 to enable 6 x xtal multiplier on 9851 set to 0x000 for 9850
pulseHigh(FQ_UD); // Done! Should see output
// transfers a byte, a bit at a time, LSB first to the 9851 via serial DATA line
void tfr_byte(byte data)
for (int i=0; i<8; i++, data>>=1) {
digitalWrite(DATA, data & 0x01);
pulseHigh(W_CLK); //after each bit sent, CLK is pulsed high
void setincrement(){
if(increment == 1){increment = 10; hertz = "10 Hz"; hertzPosition=5;}
else if(increment == 10){increment = 50; hertz = "50 Hz"; hertzPosition=5;}
else if (increment == 50){increment = 100; hertz = "100 Hz"; hertzPosition=4;}
else if (increment == 100){increment = 500; hertz="500 Hz"; hertzPosition=4;}
else if (increment == 500){increment = 1000; hertz="1 Khz"; hertzPosition=6;}
else if (increment == 1000){increment = 2500; hertz="2.5 Khz"; hertzPosition=4;}
else if (increment == 2500){increment = 5000; hertz="5 Khz"; hertzPosition=6;}
else if (increment == 5000){increment = 10000; hertz="10 Khz"; hertzPosition=5;}
else if (increment == 10000){increment = 100000; hertz="100 Khz"; hertzPosition=4;}
else if (increment == 100000){increment = 1000000; hertz="1 Mhz"; hertzPosition=6;}
else{increment = 1; hertz = "1 Hz"; hertzPosition=5;};
lcd.setCursor(0,1);
lcd.print(" ");
lcd.print(hertz);
delay(250); // Adjust this delay to speed up/slow down the button menu scroll speed.
void showFreq(){
millions = int(rx/1000000);
hundredthousands = ((rx/100000)%10);
tenthousands = ((rx/10000)%10);
thousands = ((rx/1000)%10);
hundreds = ((rx/100)%10);
tens = ((rx/10)%10);
ones = ((rx/1)%10);
lcd.setCursor(0,0);
lcd.print(" ");
if (millions > 9){lcd.setCursor(0,0);}
else{lcd.setCursor(1,0);}
lcd.print(millions);
lcd.print(".");
lcd.print(hundredthousands);
lcd.print(tenthousands);
lcd.print(thousands);
lcd.print(".");
lcd.print(hundreds);
lcd.print(tens);
lcd.print(ones);
lcd.print(" Mhz ");
memstatus = 0; // Trigger memory write
void storeMEM(){
//Write each frequency section to a EPROM slot. Yes, it's cheating but it works!
EEPROM.write(0,millions);
EEPROM.write(1,hundredthousands);
EEPROM.write(2,tenthousands);
EEPROM.write(3,thousands);
EEPROM.write(4,hundreds);
EEPROM.write(5,tens);
EEPROM.write(6,ones);
memstatus = 1; // Let program know memory has been written
The error I'm getting when trying to upload to my NANO
In file included from /Users/mirxan/Documents/Arduino/Arduino-AD9851-DDS-Direct-Digital-synthesizer-Signal-Generator-master/Arduino DDS 2/AD9851_LCD_ROTARY_WMENUS/AD9851_LCD_ROTARY_WMENUS.ino:9:0:
/Users/mirxan/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/libraries/EEPROM/src/EEPROM.h:43:30: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
operator const uint8_t() const { return **this; }
/Users/mirxan/Library/Arduino15/packages/arduino/hardware/avr/1.6.21/libraries/EEPROM/src/EEPROM.h:92:26: warning: type qualifiers ignored on function return type [-Wignored-qualifiers]
operator const int() const { return index; }
/Users/mirxan/Documents/Arduino/Arduino-AD9851-DDS-Direct-Digital-synthesizer-Signal-Generator-master/Arduino DDS 2/AD9851_LCD_ROTARY_WMENUS/AD9851_LCD_ROTARY_WMENUS.ino: In function 'void loop()':
/Users/mirxan/Documents/Arduino/Arduino-AD9851-DDS-Direct-Digital-synthesizer-Signal-Generator-master/Arduino DDS 2/AD9851_LCD_ROTARY_WMENUS/AD9851_LCD_ROTARY_WMENUS.ino:77:26: warning: comparison between signed and unsigned integer expressions [-Wsign-compare]
Archiving built core (caching) in: /var/folders/1y/gz925xkn7hbfdksl2kvf66ch0000gn/T/arduino_cache_84420/core/core_arduino_avr_nano_cpu_atmega328_fa1b08b34ccd52872ebff4bfcb4298c8.a
Sketch uses 7050 bytes (22%) of program storage space. Maximum is 30720 bytes.
Global variables use 219 bytes (10%) of dynamic memory, leaving 1829 bytes for local variables. Maximum is 2048 bytes.
avrdude: ser_open(): can't open device "/dev/cu.usbmodem1421": No such file or directory
Problem uploading to board. See
http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Invalid library found in /Users/mirxan/Documents/Arduino/libraries/RotarySource: /Users/mirxan/Documents/Arduino/libraries/RotarySource
Any suggestions?
