I'm trying to use the Cosmic compiler with the STVD program (that keep crashing) from st micoelectronic. I want to create an hex file at the build process but I can't get the output adress path right . The content always end up in the console.
the syntax goes
"chex main.o -fi -o?" , -fi being the command to convert to hex, but what do I put after the -o command ?
I tried many things without success.
