As others have said:
The parallel data is coming in at the full 165MHz. To process video at this rate, if you had ZERO wait state 24 bits of static ram, and only wanted to write exclusively, you need 6ns writes. If you want to simultaneously read and write to your memory, you need a zero wait state of 3ns. Figure under 2.5ns 24 bit DRAM running at least at 400MHz with at least 4 full page cache rams, 2 read, 2 write running at the full 400MHz on the DRAM memory side, 165MHz on each video in and out side.
Helpful hint (for regular 24bit DVI/HDMI):
1080p @ 60Hz delivers 148.5 million 24bit bit pixels a second.
720p @ 60Hz /1080i @ 60 Laced Hz delivers 74.25 million 24bit bit pixels a second.
480p @ 60Hz delivers 27 million 24 bit pixels a second.
You need a DVI decoder IC unless you go to a FPGA which can do 3 parallel 3GB/sec receivers, plus a fourth for the reference fame clock, and even then, you still need a receiver cable length equalizer amp circuit, preferably with a reclocker not to mention the HELL of getting the decoder parallel deserializer, with data skew allowance between the 3 channels, software working. It's bad enough setting the I2C controls on some of the DVI/HDMI decoder ICs alone, even though they advertise that they do everything on their own.
If you are going with small PLDs, 1 you would be forced to use a DVI decoder IC most likely from TI or Analog Devices. Unless you go for a huge IO count, complex ram controller and everything else, with only 101 IOs on a 144 pin QFP, I would say only wire 12 bit video and live with a crummy image, or, maybe even 16bit. Otherwise, you need to find at least a 240 pin QFP and some fast DRAM running at least at 200MHz DDR, or 400MHz data with 48 bit with a partial line cache within the PLD, or, 24 bits ram, say 500MHz, with at least 4 full lines of video cache on the PLD if you plan on generating a picture out while receiving a picture in simultaneously. You can relax these values quite a bit if you are only storing a picture, or, outputting a picture, but not both at the same time.
1920 x 24 bit x 4 lines = at least 196608 bits of ram just for line buffers.
This is not impossible, however, I would think you need to go to a large 480 pin BGA FPGA with 666MHz DDR2/3 ram at 64 bits support at a minimum to attempt simultaneous realtime video capture and playback.
My scalar uses 2 x 64 bit SODIMM modules and has a 780 pin BGA FPGA, but, it supports 2 simultaneous 30 bit video inputs with 30 scalable video out with picture-in-picture support.
