Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Electronics
Microcontrollers
DALI TX opto should have greater CTR?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: DALI TX opto should have greater CTR? (Read 1272 times)
ocset
Super Contributor
Country:
on:
December 06, 2017, 08:42:36 pm »
Hello,
Figure 5, page 3, of the following DALI application note (AN1465) shows optos being used to isolate both TX and RX DALI signals….
AN1465 Application note:
http://ww1.microchip.com/downloads/en/AppNotes/01465A.pdf
Though surely, the TX opto should be a TCLT1009 (CTR of TCLT1009 = 300%) and not a TCLT1000 (CTR of TCLT1000 = 50%)?
Also, surely the RX opto should be a TCLT1000, which it indeed is.
The reason that the RX opto should be a TCLT1000 is because it has a lower capacitance seen at its emitter pin which means the rise time of the emitter can be quicker. Do you agree?
TCLT100X opto datasheet:
https://www.vishay.com/docs/83515/tclt1000.pdf
Logged
CJay
Super Contributor
Country:
Re: DALI TX opto should have greater CTR?
Reply #1 on:
December 06, 2017, 08:54:55 pm »
DALI is only 1200BPS isn't it?
Not at all convinced it's necessary for it to be faster, I'm transferring 19200 BPS logic level serial through two CNY25s, the only extra components are a couple of pull up resistors per opto.
Logged
ocset
dmills
Super Contributor
Country:
Reply #2 on:
December 16, 2017, 05:45:36 pm »
The usual problem with simple minded DALI is that the transmit edge is **overly fast** not too slow.
Check the standard, but as I recall there was a limit on how fact the line should fall when you transmit.
regards, Dan.
Logged
ocset
Print
Search
Pages: [
1
Go Up
« previous
next »
Electronics
Microcontrollers
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
