Yes, however implenting a softcore process limits the amount of logic blocks you can use. The flexibility of CPU combined with FPGA is beyond compromise.
The DE0 nano has no onboard CPU interfaced to the FPGA.Instead of this they have used a Flash ROM this seems a bit limiting as to what can be done with it don't you think?
