There are myriads of other potential ways of hiding stuff in memory, and unless your software permanently checks whether any memory area has been modified unexpectedly (using CRCs for instance, but even so, the CRCs could be compromised in the right way), you have no real means of controlling this if the areas in question are not protected anyway.
You still have a portable way of forcing padding bytes to zero.
Every time you write to a struct member, zero out the following padding bytes after the write (dummy bytes between this member and the next member) with a call to memset(). You can use offsetof() to get the index of each member inside the struct. Granted it would be cumbersome, but it works. You could then also check if the padding bytes have changed values by accessing them as bytes, again using offsetof() to compute the pointer to the padding bytes, and compare them to zero. This should do the trick in a fairly portable way, but you'd still be in a kind of gray area. Here we're assuming that only writes to struct members could be the cause of modification of padding bytes. This assumption is reasonable. But you may encounter some platform that still can't guarantee that padding bytes' values are retained even if no write occurs. It's probably very unlikely, but you have no guarantee.
