You need to get your basic terminology right before you have any chance understanding the documentation.
A PORT is the collection of the bits.
You don't have "first 8 ports available in GPIO1".
GPIO1 is the port.
I understand the concept, it is only a question of nomenclature when expressing it. A port is, for example, GPIO1, and each pin is a bit of the port, so if there are 16 input/output pins in GPIO1, each one is a bit of the port and I can read or write by DMA one or several bytes, not necessarily from the first byte, but always full bytes.
My question was about the grouping and order of the bits, in this particular case, since on the Reference Manual and the Datasheet, in the ports there are gaps between bits (for LQFP100), they are not contiguous (in appearance). Probably, internally, all these bits are contiguous , and it is not a problem, in fact when counting them I see that there are 16 bits per port, that is 2 bytes, instead of the 4 bytes that should be for the LQFP144. I will do tests, and I will check with the oscilloscope to corroborate what I suspect (internally all those bits are contiguous, although in the manual there seem to be gaps between them)
Knowing that, and that I can read or write in one of those bytes, although it is not the first one, I'm already clear about it. In my hardware, for the tests, I will have to reorder the routing of the pins of each port, to always catch bits that are part of the same port byte. At first I mixed bits of several ports and without order, for lack of information, I thought that each pin could be treated individually.
Now I am with the tests, but I am already understanding the concepts necessary to handle the DMA, especially with parallel read / write, to or from the GPIO ports. I still have to check how to configure automatically to increase the address of origin or detiny and how the circular buffer works, I have the concepts, but I lack the practice to be able to configure everything.
