I need help with this timing chart from the ST7735 datasheet. It is the timing for the bi-dir SPI + data/command line configuration. My concern is with the D/CX signal line. I am correct understanding that the driver reads the D/CX during the first clock period for the byte, that is the first bit being sent, and it does not care for its level for the rest of the byte ?
I will appreciate your comments
Tony
