The AT28C256-15PU is not fully pin compatible? Looks like the pin 1 and 27 are switched on the AT28C256 versus the AM27C256?
Hmmm you're right, ofcourse you don't have a vpp on a eeprom but the /WE is kindof same functionality abstractly seen.
How about the AT29C256?
Looks ok to me.
Ofcourse this is a flash device which has different properties than an EEprom being:
- less write cycles (typ. 10000 vs a few million for eeprom)
- page erasable sometimes only page writable instead of byte writable like an eeprom
In your case it does not matter since you only want to use it as firmware replacement (eg write once, read many).
But in case of an eprom simulator or something that is written to many many times it might be important.
