So say I set a particular pin as an input, and, and activate that pin's internal pullup.
Is there anything bad that could happen if a HIGH signal is sent to that pin, such that it's getting 5 volts from two sources at once?
Related question. Let's say I don't enable the internal pullup. The MCU can still read the pin even if it's tri-stated, right?
App specific question. I'm gathering input with a 74HC165 shift register. I'm not confident how to properly set up the MCU pin that gets the serial output from the shift register. My gut says no internal pullup, but I'm not sure.
Sent from my E6830 using Tapatalk
