You need to spin it up, and you need around 100 liters of air at at least 3-4 bars on the exhaust side, and you need to supply oil pressure to the turbo, heated oil at that, at around 3-4 bars as well, and you need to make manifolds to supply the air into the exhaust inlet, expect to spend at least some 500€ for all that if you dont already have a spare air cylinder, hydraulic pump with electric motor, plumbing, various fittings, and some decent carbide burs and a die grinder, there is also static balancing that should be done, and the wastegate needs to be set, so pressure sensors are needed as well, if it is a variable geometry turbo you will also need to set and calibrate the vanes opening and motion from 0 to at least 19 in.Hg.
EDIT:
Why dont you just buy the assembled CHRA's pre-calibrated? If you run the turbos at stock pressures and below the surge lines the chinese CHRA's can last a long time, unless you are doing hybrids and using billet compressor wheels, none the less 50€ is relatively cheap to have it all calibrated by a 3rd party, if it blows up in 2 days you have someone to blame for.
