Author Topic: EE-TOOLS EeRom-8U, 8-bit EPROM/Flash emulator up to 8M-45ns USB port: protocol ?  (Read 4218 times)
Offline legacyTopic starter
hi
i am still looking for a good eprom emulator, something that
  • is faster than 1Mbps
  • is able to handle 3.3V/5V
  • is USB driven
EE-TOOLS EeRom-8U, 8-bit EPROM/Flash emulator up to 8M-45ns USB port, is exactly what i am looking for !
it is 10Mbps, it is 3.3V/5V and it is USB driven !
the only defect: the protocol is not documented, it is not open, you can only use this device on Windows !
for my purpose i need to connect the eprom emulator to a linux MIPS/SoC, so i need sources, perhaps, i need to know the protocol in order to drive the usb-device
anybody knows this eprom emulator ? anybody knows something about its protocol ? any hack around ?
If your browser can hit it, here it is an auction on ebay.
here, the LEAP ELECTRONIC  WICE-M4  EMULATOR, 4MB ROM, USB INTERFACE is an other good usb eprom emulator, i am not able to understand how fast is it about the upload, also … it seems closed protocol, too
which software can i use to reverse the protocol over the usb bus ?
about eprom-emulator, i have found this funny project  :-DD
Offline abyrvalg
Offline AlexxGreen
Did you try an app like USB port Sniffer (http://www.eltima.com/products/usb-sniffer/)?
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
Arduino Template Library | Zalt Z80 Computer
Wrong code should not compile!
Offline ale500
You need to reverse engineer the protocol, test and develop new software...
I just wonder, because you seem to dive quite deep into electronics, if it may be an alternative to develop your own:
Big SRAM with bus isolators and a STM32F4 to program it, it has HS interface. or using one of those FT2322 or similar, they go up to 12 Mbps or similar.
I also need something like this, but for only 8 to like 32 kBytes and 16 bit :)
dude, 2 years later? Already solved 1 year ago  :-DD
Offline eliocor
    • rhodiatoce
Just for curiosity: what was your end choice?
