Hi all,
I'm wondering what you might suggest for free tools and techniques to write embedded textual (non graphical) UIs on systems having things like multi-line character LCD screens, non-full keyboard keypads like number pads / discrete buttons / button oriented touch screens etc. Like maybe a vending machine or irrigation controller or credit card terminal or such kind of thing.
Obviously it is fairly simple (but tedious) to hardcode such a UI by embedding the screen control and input event processing into application specific manually written UI state machine code and you'd end up with something like an old "curses" (UNIX) type application.
That is fine but it seems a little primitive by today's standards where most UIs can be created by RAD tools and easily authored / "emulated" on PCs and then the code or at least the configuration data for the text / UI state flow generated by the authoring tool.
So with certain authoring / application platforms one might use something like Microsoft Expression Blend, QtCreator, technologies like QML, XAML, WML, UML and their authoring programs, and create some kind of code from the RAD UI generator program or some UML tool to create the UI state flow model and probably bind that to the UI event / output data as well, maybe ending up with some ad-hoc generated application code or maybe some MVC type of framework with application specific UI data bound to it. Obviously there are similar authoring systems for things like FLASH etc.
Hyper card authoring or interactive web page authoring could be similar in many respects.
But when the target UI input devices are are embedded sorts of things that require some unique input processing besides raw HID data, and the output display is more minimal more like a serial terminal (like WML or curses might target), what's a good way to implement such a UI besides the "ad hoc" manual way or one step up and maybe manually doing UML for the whole thing followed by conversion of that model to data + code?
What more modern and free UI libraries / authoring tools / methodologies can one use to target such embedded systems applications most easily to facilitate PC based authoring / preview and have the code/data end up useful to port to an embedded system?
I've seen libraries like emWin but AFAIK that's not quite what I'm looking for (due to high cost and also not really oriented to my desires as far as I recall), I'm more wondering how one would use closer to "PC / web application normal" GUI / RAD / WYSIWYG hypertext page authoring tools and end up going through something like XML/WML/XAML/QML/UML or whatever to end up with something that is perhaps basically generated code / "database" (or hardcoded string atoms?) and MVC / other state machines in C or Python or something that's suitable for an embedded target.
Rendering HTML pages as UI on the target seems a bit too heavyweight (though maybe WML or SIMPLE HTML/SGML might work if using some kind of super minimal rendering library) so more something that could translate into some kind of C/C++/Python MVC or whatever application with something more like a "curses" library backend might be more like it.
What do you use in cases that are a few steps up from trivial but a few steps down from where you'd use an embedded GUI library stack based / or HTML UI? Particularly in cases where you might want to change the UI to customize it for various variant use cases and one would rather not just code it all manually if possible for every sort of change.
Seems like there ought to be some good TUI libraries / toolkits / authoring tools.
Or if the target was to support some kind of simple HTML based UI, what's a good option to render that to a text screen model and maybe handle HID UI and such events to send them back to some kind of XFORMS or whatever control stream back to the input processing view controller?
Edit: I guess an XML and maybe some kinds of XFORMS or similar system would work fine for encoding the target's output text and maybe also representing what kind of inputs are expected / required and how they should be processed (input events triggering some kind of XQUERY or other scripting to change the UI state and then emit the new state's XML view data...? But even if XML or JSON or whatever was used to encode the UI MVC system how does that translate to what is easy to generate and author on a PC without writing a customish web application / application for the purpose?
