Author Topic: How to start to write UART bootloader for PIC24FJ128GB206  (Read 1765 times)
Offline muthukural001Topic starter
  • Country: in
« on: April 27, 2018, 12:42:50 pm »
Hello All,
I have a project which occupied 82% of flash memory. Right now, I have to write UART bootloader for this. As I did not work with any Bootloader reviously,  I really need some help to start. Please suggest.
Regards,
muthu
Offline mikerj
Re: How to start to write UART bootloader for PIC24FJ128GB206
« Reply #1 on: April 27, 2018, 01:21:03 pm »
Have you looked at Microchips AN1157 app note?  There is also the Easy Bootloader library with examples.
  • Country: in
« Reply #2 on: April 27, 2018, 06:06:06 pm »
Thanks. I downloaded and tried to run  the ex_boot_uart MPLAB X project from the "ezbl" zip with the change of target device to PIC24FJ128GB206 by make use of project properities. But, I am getting error as shown in the attached. Then, I  saw a folder named "Hardware Initializers" which have .c files for specific PIC24 and dspic microcontrollers.If I change target device to one of the microcntrollers that is in the folder and compile, I am able to compile successfully.Unfortunately, Our microcontroller is not listed there. How to get rid of this problem. Please suggest.
