Did you check the various docs here? http://support.dooao.com/?/explore/Found another SDK there also, DooaoSDK package with sources and drivers for things, but not sure if that is the same as in the other sdk's. (probably is)
This doc have an newer date than the one referenced on your blog:https://www.mikrocontroller.net/attachment/231858/0A-ESP8266_Specifications_v4.pdfBtw, the colors on your blog makes links unreadable, grey on black..
Hackaday just published:http://hackaday.com/2015/03/18/how-to-directly-program-an-inexpensive-esp8266-wifi-module/
At the end they thank https://nurdspace.nl/ESP8266 for their Chinese datasheet translation. All they revealed is that the non-rf ADC is on SPI_EN1.Then someone on reddit decapped it and found it's really a ESP8089. But I got less on that chip than the ESP8266. http://www.reddit.com/r/electronics/comments/2jq22l/esp8266_wifiserial_chip_decapped_its_actually/
If you could gain control of the adc, you could potentially make this a sdr.
