Author Topic: ESP8266 - LM75 I2C temperature sensor - LCD display  (Read 2857 times)
Offline TJ232Topic starter
  • www.esp8266-projects.org
    • ESP8266 Projects
« on: April 03, 2015, 11:37:06 am »
   I was asked if MCP9008 Temperature sensor can be replaced with the cheaper and widely available LM75 one.
The answer is YES, it can be done without any problems, actually they can share same slot on CBDB Dev Board without any hardware changes as pin compatible, just choose your desired I2C address with the A0, A1, A2 pins.
More details : http://www.esp8266-projects.com/2015/04/lm75-i2c-temperature-sensor-driver-cbdb.html
Video:
ESP8266 Projects - www.esp8266-projects.org
MPDMv4 Dimmer Board available on Tindie: https://www.tindie.com/stores/next_evo1/
