Author Topic: ESP8266 - Very useful video  (Read 5907 times)
Offline Xenon PhotonTopic starter
  • Country: eg
« on: February 13, 2016, 01:50:28 pm »
I just found this video from the State of Electronics very useful and wanted to share with you.
Offline farsi
Re: ESP8266 - Very useful video
« Reply #1 on: February 19, 2016, 12:35:11 pm »
thanks, indeed it looks nice.
still looking for some cheap programming breakout board for the ESP8266 01
I saw some on OSHPark to help breakout the board for breadboards, but first one needs to flash the board. Surprisingly, there is no "plug and play" solution for this yet.
  • Country: eg
« Reply #2 on: February 19, 2016, 10:15:14 pm »
I made breakout boards like this.
To program them, I connect GPIO0 to GND to enter boot mode.
Offline captbill
« Reply #3 on: February 20, 2016, 01:00:35 am »
I found a really neat little board provider on Ebay. These are quite versatile boards and very reasonably priced too.
Here is a complete kit for $5.99:
http://www.ebay.com/itm/NodeMCU-Alternative-DIY-Prj-Brd-ESP8266-ESP-12E-USBTLL-Arr1-8BizDay-/271999102550
Lot's of other ESP8266 goodies in his Ebay Store too:
http://stores.ebay.com/tomyuen007
Offline wblock
« Reply #4 on: February 20, 2016, 02:47:26 am »
There are a lot of accessories with that, but a NodeMCU has an integrated 1117 and USB UART and fits on a breadboard.
Offline TJ232
  • www.esp8266-projects.org
    • ESP8266 Projects
« Reply #5 on: February 20, 2016, 06:32:20 am »
A while ago I've done a very simple breakout board with regulator and decent spacing that fits ESP07-12. Cut it in a half and voila, simple breakout board :). It's designed for easy cut.
PCB available for order directly at the DirtyPCB House:
http://dirtypcbs.com/view.php?share=5615&accesskey=401e206b2272f21313417ca77c1616d4
ESP8266 Projects - www.esp8266-projects.org
MPDMv4 Dimmer Board available on Tindie: https://www.tindie.com/stores/next_evo1/
Offline farsi
« Reply #6 on: February 22, 2016, 01:30:01 pm »
nice, these simple breakout boards are my motivation to experiment more with PCB design too.
but the ESP8266 breakout boards below looks to be of SMD type for soldering?
I only have basic soldering equipment.
Offline TJ232
    • ESP8266 Projects
« Reply #7 on: February 23, 2016, 05:29:19 am »
Smallest used parts at above are 1206, especially to be also easy hand soldered if necessary.
