You can swap the two conductors that make up each pair, and unless auto-MDIX is turned off for some reason, you can usually exchange the Tx and Rx pairs.
I'm fairly sure Gbit Ethernet allows the order of all four pairs to be switched around, though I've not tested this.
You can't swap individual conductors between pairs; the right pairs of wires must be twisted together. A pair must remain a pair.
