All the platform needs is a good orientation. The datasheets aren't great, but they're probably sufficient once you are a little familiar.
Another thing that would help is a simple reference schematic for each part showing recommendations for power supply, clocking, and any tricky peripherals (e.g., USB SoftConnect) like you would find in any IC datasheet. A well-documented dev board would be OK too. (Although you still may not immediately see the difference between optional components and the bare-bones requirements.)
In most cases, it's pretty standard fare, but I had some initial questions that took a while to find answers to. Here are some examples: V3.3 and the pins that supply internal 1.8v core regulators -- both OK with just a typical 100nF decoupling cap, or do I need larger caps and/or some isolation? Does the RTC crystal need load caps, or is there sufficient load through the oscillator pins? Is it recommended to tie USB VBus directly to the Vbus_detect pin, or should I clamp it with a resistor and Zener? (It is a 5v tolerant pin, but who knows what's going to happen on the bus power rail.) Does the JTAG Reset pin go to MCU Reset or JTAG TRst? Does it need a pull-up?
A lot of those questions aren't just dumb newbie things. The official answer in many cases is: "It depends." Most sources tell you to look at the manufacturer's documentation. E.g., JTAG requires pull-ups, but they "may" be internal. Same with the RTC load caps -- required, but possibly not as external components.
It must be tough, as a vendor, remembering what it's like on Day One with a new MCU, because most of them seem oblivious to the fact that their potential users haven't been present in all those internal design meetings. No one's born with that knowledge, and coming from other platforms, or even other vendors' take on the same platform, doesn't necessarily give you anything more than a "feel" for what's correct.
