Except for one shots, scopes are designed to show signals which are repetitive. What is displayed is an overlay of a short window in time whose start is either periodic in the case of recurrent sweep "auto" mode or which is periodic relative to some arbitrary trigger.
That is of course the crux here. All modern scopes are "one shot" or real time sampling.
The only exception are equivalent time sampling scopes for the highest possible bandwidth requirements, in which case the signal needs to be periodic, since the actual sample rate is rather low.
So what you are proposing is really a subsampling scope that will be able to restore a repetitive waveform from a smaller set of samples than traditional sampling scopes.
While this is definitely an interesting approach, I don't see a commercial market for it. Existing sampling scopes do an excellent job and don't have any need to reduce ADC or storage speed requirements. All the magic is in the sampler and the time base. The conversion and data processing takes place at a very leisurely pace.
More importantly for any market interest, sampling scopes are a tiny fraction of all scope, precisely because they lack universal usefulness. They simply can't see the glitches that we need to see in digital systems.
The argument that compressive sampling will see some of the glitches some of the time is true, but it would take a much longer measurement time to even find a single one.
