It's finally the weekend so I've had some more time to look at this again and I've redesigned as suggested by using only a single multiplier per channel. But I'm still running into the issue that ISE doesn't like the way I've defined my coefficients. Below is an example of how I do it.
localparam num_taps = 1000;
localparam coeff_scale = 16;
localparam signed[17:0] coeff[0:999] = '{0, 3, 5, 8, 9, 10, 10, 9, 6, 3, 0, -4, -8, -11, -13, -14, -13, -11, -8, -4, 0, 4, 9, 12, 14, 15, 14, 12, 9, 5, 0, -4, -7, -10, -12, -12, -11, -9, -7, -4, -1, 2, 4, 6, 6, 6, 5, 4, 2, 1, 0, 0, 0, 1, 2, 3, 4, 4, 4, 3, 1, -2, -5, -8, -11, -13, -14, -14, -12, -8, -3, 3, 9, 15, 20, 23, 24, 22, 19, 13, 5, -3, -11, -19, -25, -28, -29, -27, -22, -15, -7, 2, 11, 19, 24, 27, 28, 25, 20, 14, 6, -1, -8, -13, -17, -18, -18, -15, -12, -8, -3, 0, 3, 4, 3, 2, 0, -2, -3, -4, -3, 0, 4, 9, 14, 19, 23, 24, 23, 19, 11, 2, -10, -21, -32, -40, -45, -46, -42, -33, -20, -4, 13, 30, 44, 55, 61, 61, 54, 43, 26, 7, -13, -31, -47, -58, -63, -62, -55, -43, -27, -9, 9, 25, 38, 46, 48, 46, 39, 29, 18, 6, -4, -12, -17, -18, -16, -13, -8, -3, 0, 1, -1, -5, -12, -20, -27, -33, -35, -32, -25, -13, 4, 23, 42, 59, 73, 80, 79, 69, 51, 26, -3, -35, -65, -90, -108, -115, -112, -96, -71, -38, 0, 39, 74, 102, 121, 128, 122, 104, 76, 42, 4, -33, -65, -89, -104, -107, -100, -83, -60, -33, -6, 19, 39, 51, 56, 54, 46, 34, 21, 10, 2, -2, 0, 6, 16, 26, 34, 38, 36, 26, 9, -14, -42, -70, -95, -114, -122, -117, -99, -68, -25, 24, 76, 124, 163, 188, 195, 183, 152, 103, 42, -25, -93, -152, -199, -226, -231, -214, -175, -120, -53, 19, 87, 146, 188, 211, 212, 193, 156, 106, 49, -9, -60, -101, -127, -137, -132, -114, -87, -55, -24, 1, 19, 26, 24, 14, 0, -14, -25, -28, -20, -1, 27, 63, 100, 134, 158, 167, 158, 128, 78, 12, -65, -144, -216, -272, -305, -309, -280, -221, -135, -30, 84, 196, 292, 363, 399, 397, 356, 278, 172, 48, -82, -203, -304, -373, -406, -398, -351, -272, -169, -55, 59, 160, 239, 289, 305, 290, 248, 186, 113, 39, -26, -75, -105, -113, -103, -79, -49, -20, 0, 6, -6, -34, -75, -123, -169, -203, -216, -201, -155, -79, 23, 141, 262, 371, 454, 497, 492, 432, 321, 166, -21, -219, -409, -570, -682, -731, -708, -613, -453, -241, 0, 247, 475, 659, 781, 826, 789, 676, 498, 273, 26, -217, -431, -595, -693, -719, -673, -564, -408, -225, -38, 132, 267, 355, 391, 377, 323, 242, 152, 70, 12, -13, 0, 47, 116, 193, 258, 291, 277, 205, 72, -113, -335, -568, -781, -943, -1023, -997, -852, -590, -224, 215, 686, 1140, 1523, 1785, 1886, 1799, 1516, 1051, 439, -267, -999, -1682, -2241, -2609, -2737, -2596, -2185, -1533, -694, 256, 1225, 2115, 2833, 3298, 3454, 3275, 2766, 1969, 954, -183, -1332, -2377, -3213, -3752, -3934, -3735, -3170, -2288, -1173, 66, 1310, 2435, 3329, 3904, 4102, 3904, 3329, 2435, 1310, 66, -1173, -2288, -3170, -3735, -3934, -3752, -3213, -2377, -1332, -183, 954, 1969, 2766, 3275, 3454, 3298, 2833, 2115, 1225, 256, -694, -1533, -2185, -2596, -2737, -2609, -2241, -1682, -999, -267, 439, 1051, 1516, 1799, 1886, 1785, 1523, 1140, 686, 215, -224, -590, -852, -997, -1023, -943, -781, -568, -335, -113, 72, 205, 277, 291, 258, 193, 116, 47, 0, -13, 12, 70, 152, 242, 323, 377, 391, 355, 267, 132, -38, -225, -408, -564, -673, -719, -693, -595, -431, -217, 26, 273, 498, 676, 789, 826, 781, 659, 475, 247, 0, -241, -453, -613, -708, -731, -682, -570, -409, -219, -21, 166, 321, 432, 492, 497, 454, 371, 262, 141, 23, -79, -155, -201, -216, -203, -169, -123, -75, -34, -6, 6, 0, -20, -49, -79, -103, -113, -105, -75, -26, 39, 113, 186, 248, 290, 305, 289, 239, 160, 59, -55, -169, -272, -351, -398, -406, -373, -304, -203, -82, 48, 172, 278, 356, 397, 399, 363, 292, 196, 84, -30, -135, -221, -280, -309, -305, -272, -216, -144, -65, 12, 78, 128, 158, 167, 158, 134, 100, 63, 27, -1, -20, -28, -25, -14, 0, 14, 24, 26, 19, 1, -24, -55, -87, -114, -132, -137, -127, -101, -60, -9, 49, 106, 156, 193, 212, 211, 188, 146, 87, 19, -53, -120, -175, -214, -231, -226, -199, -152, -93, -25, 42, 103, 152, 183, 195, 188, 163, 124, 76, 24, -25, -68, -99, -117, -122, -114, -95, -70, -42, -14, 9, 26, 36, 38, 34, 26, 16, 6, 0, -2, 2, 10, 21, 34, 46, 54, 56, 51, 39, 19, -6, -33, -60, -83, -100, -107, -104, -89, -65, -33, 4, 42, 76, 104, 122, 128, 121, 102, 74, 39, 0, -38, -71, -96, -112, -115, -108, -90, -65, -35, -3, 26, 51, 69, 79, 80, 73, 59, 42, 23, 4, -13, -25, -32, -35, -33, -27, -20, -12, -5, -1, 1, 0, -3, -8, -13, -16, -18, -17, -12, -4, 6, 18, 29, 39, 46, 48, 46, 38, 25, 9, -9, -27, -43, -55, -62, -63, -58, -47, -31, -13, 7, 26, 43, 54, 61, 61, 55, 44, 30, 13, -4, -20, -33, -42, -46, -45, -40, -32, -21, -10, 2, 11, 19, 23, 24, 23, 19, 14, 9, 4, 0, -3, -4, -3, -2, 0, 2, 3, 4, 3, 0, -3, -8, -12, -15, -18, -18, -17, -13, -8, -1, 6, 14, 20, 25, 28, 27, 24, 19, 11, 2, -7, -15, -22, -27, -29, -28, -25, -19, -11, -3, 5, 13, 19, 22, 24, 23, 20, 15, 9, 3, -3, -8, -12, -14, -14, -13, -11, -8, -5, -2, 1, 3, 4, 4, 4, 3, 2, 1, 0, 0, 0, 1, 2, 4, 5, 6, 6, 6, 4, 2, -1, -4, -7, -9, -11, -12, -12, -10, -7, -4, 0, 5, 9, 12, 14, 15, 14, 12, 9, 4, 0, -4, -8, -11, -13, -14, -13, -11, -8, -4, 0, 3, 6, 9, 10, 10, 9, 8, 5, 3};
I get the error:
ERROR:HDLCompiler:806 - "filter_coeff_15.h" Line 3: Syntax error near "'".
So it doesn't like the single quote before the "{". But my understanding is that this is how this is defined. If I remove the single quote then it will compile but I get 12000 warnings and the design is too large for the FPGA. I think it's treating the coefficient as like 18000 bit register or something. What am I doing wrong here?
In case it's useful below is my current code. I haven't tested it yet because of the above problem so there might be errors.
`timescale 1ns / 1ps
module Bandpass_Filter(
input wire clk,
input wire reset,
input wire[11:0] data_in,
output reg signed[11:0] data_out
`include "filter_coeff_15.h" // This file contains the information about the filter.
integer i;
reg shift; // Shifts data in.
reg[15:0] data_index; // Index of the delay data. This should be parameteized later.
reg signed[17:0] data_delay[0:num_taps-1]; // Data in.
wire signed[47:0] product; // Results of multipication.
reg signed[47:0] carry_in; // Carry in, carry out from last calculation.
always @(posedge clk or negedge reset) begin
if(!reset) begin
shift <= 0;
carry_in <= 0;
data_out <= 0;
for(i=0; i<num_taps; i=i+1) begin : data_reset
data_delay[i] <= 0;
end
end else begin
if(!shift) begin // Operate on the data when not shifting.
if(data_index < num_taps) begin
data_index <= data_index + 1;
carry_in <= data_delay[data_index]*coeff[data_index] + carry_in; // Later buffer the coefficent value rather than accessing directly.
end else begin
shift <= 1; // Delete later
end
end else begin // Shift data when new data arrives.
data_index <= 0;
carry_in <= 0;
shift <= 0; // Delete later.
data_out <= carry_in >>> coeff_scale; // Scale the data and output it.
data_delay[0] <= {6'b0, data_in}; // Take in the new data;
for(i=1; i<num_taps; i=i+1) begin : gen_data_shift // Shift all the data.
data_delay[i] <= data_delay[i-1];
end
end
end
end
endmodule
