Author Topic: vhdl Alliance, VLSI/CAD System  (Read 1737 times)
Offline legacyTopic starter
« on: August 16, 2017, 10:14:49 pm »
Abstract
Alliance is a complete set of free cad tools and portable libraries for vlsi design. It includes a vhdl compiler and simulator, logic synthesis tools, and automatic place and route tools. A complete set of portable cmos libraries is provided. Alliance is the result of a twelve year effort spent at SoC department of LIP6 laboratory of the Pierre & Marie Curie University (Paris VI, France). Alliance has been used for research projects such as the 875 000 transistors StaCS superscalar microprocessor and 400 000 transistors ieee Gigabit HSL Router.
alliance
Does anyone happen to use it?
It might be used as simulator.
Tried today from the git-repository.
It seems it comes with limited vhdl-features, e.g. it seems it doesn't support library and generic port.
btw, the following worked
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity priority_encoder is
port
 in_data  : in  std_logic_vector (7 downto 0);
 out_data : out std_logic_vector (3 downto 0)
end priority_encoder;
architecture behavioral of priority_encoder is
begin
  process (in_data)
    variable first_one: std_logic:=0;
  begin
    first_one:= '0';
    out_data<=(others=>'0');
    for i in in_data'range loop
      if ((not first_one) and (in_data(i)='1')) then
        first_one:='1';
        out_data<=std_logic_vector(to_unsigned(i,out_data'length));
      end if;
    end loop;
  end process;
end behavioral;
priority_encoder_2.vhd
with this pat file
--port list
--inputs
in       in_data (7 downto 0) X;;;
--outputs
out      out_data (3 downto 0) X;;;
begin
--Signal list
<   0 fs>  : 00 ?0 ;
<  20 fs>  : 01 ?0 ;
<  20 fs>  : 02 ?1 ;
<  20 fs>  : 04 ?2 ;
<  20 fs>  : 08 ?3 ;
<  20 fs>  : 10 ?4 ;
<  20 fs>  : 20 ?5 ;
<  20 fs>  : 40 ?6 ;
<  20 fs>  : 80 ?7 ;
end;
priority_encoder_2.pat
vasy -I vhd -Vao priority_encoder_2
asimut -b priority_encoder_2 priority_encoder_2 priority_encoder_out
 :popcorn:
Re: vhdl Alliance, VLSI/CAD System
« Reply #1 on: August 16, 2017, 10:18:38 pm »
to visualize results, you need to invoke xpat
« Reply #2 on: August 18, 2017, 10:02:07 am »
Made a simple ebuild for gentoo with the last repository version of Alliance.
It needs autogen, and ... I had to remove the LaTeX documentation autobuild.
it uses OpenMotif X11 libraries, thus it's a good software for old UNIX (e.g. IRIX) and X11-terminals pre-GTK (e.g. Tektronix XP200/400, HP-i960 ... )
 :popcorn:
