Active Serial == SPI
Ok, so I've wrapped my mind around this much so far. But what about the chip commands? I may still be failing to understand something basic here, but as I've been reading endless amounts of datasheets, I see that these SPI Flash chips have certain command codes that need to be shifted into them in order to tell it whether you're doing a read, a write, giving it a target address, etc.
Are these command codes going to be compatible with the "language" spoken by Altera's FPGA's for their native AS configuration mode?
Again, if I'm way off base about something, let me know.
I did notice how MaxV looked more like an FPGA internally than a true CPLD, and considered ordering some to test out. Max10 sounds like a pretty exciting upgrade. 100 pin QFP's don't scare me!
