Author Topic: FPGA oscilloscope circuit  (Read 4206 times)
Offline yalectTopic starter
« on: September 24, 2018, 09:58:41 pm »
I would like to ask you if I can buy FPGA chip to build fast oscilloscope circuit.
Thank you
Online ataradov
    • Personal site
Re: FPGA oscilloscope circuit
« Reply #1 on: September 24, 2018, 10:15:10 pm »
Sure. A lot of commercial scopes are built around Xilinx Zynq, which are readily available from Digi-Key.
Alex
« Reply #2 on: September 24, 2018, 11:34:40 pm »
Sorry, I mean I am looking for simple FPGA oscilloscope circuit  which I can buy FPGA chip and program it to build fast oscilloscope.
Thanks
Online ataradov
    • Personal site
« Reply #3 on: September 24, 2018, 11:37:24 pm »
"Simple" and "fast" are not compatible. Forget about it. To build a scope, you need to have a better scope already.
Also parts separately in single quantities will cost more than a real scope. And FPGA is not the most expensive component, the ADC is.
Alex
Offline NorthGuy
« Reply #4 on: September 24, 2018, 11:40:02 pm »
Thanks
Absolutely. It won't be cheap though:
https://www.xilinx.com/products/silicon-devices/soc/rfsoc.html
Offline nctnico
« Reply #5 on: September 25, 2018, 12:03:42 am »
Red Pitaya en Digilent AD2 come to mind.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #6 on: September 25, 2018, 12:08:36 am »
fast is a relative term. we can say 100MSa/s is fast compared to 1MSa/s... to OP, here is your cheap and fast solution...
https://www.ebay.com.my/itm/DSO168-Handheld-mini-pocket-digital-oscilloscope-20M-bandwidth-100M-sampling/123119301045?hash=item1caa7b71b5:g:8JIAAOSwIIha76hM
no need to build anything...
Offline Morgan127
« Reply #7 on: September 25, 2018, 06:02:37 am »
I use this Internal Logic Analyzer and displays the data as analog. This works up to approx 300-MSps I guess.
The screen update rate looks like any other oscilloscope. Using this you can use almost any Xilinx-fpga/boards.
It is also free to download and use.
Offline NorthGuy
« Reply #8 on: September 25, 2018, 01:12:38 pm »
... displays the data as analog. This works up to approx 300-MSps I guess.
Is that with built-in 1MS/s ADC?
Offline Morgan127
« Reply #9 on: September 25, 2018, 01:27:13 pm »
No that is with external ADC. With the internal XADC you get 1 MSps max.
Offline NorthGuy
« Reply #10 on: September 25, 2018, 01:54:54 pm »
What external ADC do you use it with?
Online PCB.Wiz
« Reply #11 on: September 25, 2018, 08:53:52 pm »
Thanks
Do you mean a pre-built module when you say "simple FPGA oscilloscope circuit" ?
You can use almost any FPGA out there, as a basis for an oscilloscope.
The FPGA is only a small portion of the puzzle.
You also need fast transport to some PC host, and a fast ADC.
Those items are harder to define, and design with, than a FPGA.
eg you might select a FT60x USB-3 bridge device, as the fast PC host link, then you need to bridge between that and your ADC, using the FPGA
To find a module, you could drop into Digikeys search engine for
Evaluation Boards - Analog to Digital Converters (ADCs)
and pick some MSPS that meets your 'fast', then sort by price.
Or, you could browse Module companies, like
https://www.trenz-electronic.de/en/Company/Projects/4-channel-Flash-ADC/
No price there, but that says " sampling rates up to 5 GHz." so might meet your 'fast' ?
and from above
https://shop.trenz-electronic.de/en/Red-Pitaya/
https://shop.trenz-electronic.de/en/27069-Analog-Discovery-2?c=76
or
https://www.scopefun.com/
or
https://hackaday.com/2017/11/18/ds212-oscilloscope-review-open-source-and-great-for-hacking/
or
https://www.makerfabs.com/fabs/index.php?route=product/product&product_id=524
Offline rhb
« Reply #12 on: September 25, 2018, 10:40:23 pm »
The cheap and easy solution is to buy an Instek GDS-2072E and hack it.  It's everything you need.  I've set up a Zynq/Cyclone dev platform to implement FOSS FW for COTS DSOs.  There's a thread on that. At the moment I'm rewiring my workspace.   I bought my 2072E (now at 300 MHz) as a test bed with the good luck to get it for $244 from Amazon.  However, even at the regular price, it's a good platform.  I think Siglent also sell a Zynq based DSO.
ALL the low cost DSOs are FPGA based so anyone of those will work. The Zynq is particularly attractive because the boot is public stated.
If you want "fast"  as in 2-3 GHz BW, you might want to consider buying a LeCroy DDA-120 and the FPGA board of your choice.  Replace the CRT with a $90 RPi display and use all that space to put proper anti-alias filters. A single channel at 4 GHz Nyquist is fast!  I just bought a DDA-125 which already has the LCD display.  I think now that a 120 and a 10" VGA LCD is a better option.
There are two lines which have both an FPGA fabric and hard CPUs, the Zynq which is already in wide use for this application, and the Cyclone V.
Probably most of the chip vendors have reference designs for AFEs for DSOs.  If you want *really* fast, then there are ADC dev boards for a few $K which will give phenomenal results.
Offline haastyle
« Reply #13 on: March 08, 2019, 12:55:10 pm »
The Haasoscope fits the bill, and is open source..
https://github.com/drandyhaas/Haasoscope
