Full duplex! I intend to update the firmware in the voice cards the card has at least to say all ok, or error on frame XX
Still, i can't see the advantage of RS485 over CAN, the MCU price difference is like 0.15 in a 5-6€ figure, the can controller does a lot of things for you like framing, priorities, detecting transmission error and retransmitting on error..
Agree with CAN. Most MCUs use the same outsourced bxCAN peripheral IP, which is of fairly usable quality. You can easily configure hardware filters to only read specific CAN IDs (or masked ranges) you are interested about. You have hardware checksumming, and extremely simple framing up to 64 bits of payload, which is fairly good for synthesizer commands, I think. When 8 bytes is insufficient as is, you can dedicate part of the ID space to map certain settings or commands within the same unit, especially if you use the extended 29-bit IDs. Then, for example, just map the lowest 8 bits of the ID to denote actual "command" or "variable address" within one unit.
This is all very simple - again it's basically sharing memory, instead of developing "communication protocols" and "writing parsers".
Retransmission on CRC error, by the way, is very nontrivial in a UART message parser. CAN does this for you. You may still want to look at some statistics for error numbers and latency, though. Luckily, the CAN peripheral almost always provides easy ways to assist this, for example, error counters and message timestamping.
