Don't blame FTDI for counterfeit chips, blame the Chinese criminals who manufactured and distributed them. You should send your faulty chips back to Farnell - I bet they won't be pleased to find out that they are fakes!
If you really believe it's not an error in your design, but instead you believe it's a counterfeit chip,what exactly was the response of Farnell after you reported it to them?
Thanks, it works under linux (linux mint under virtualbox with USB forwarding)This confirms I have a counterfeit chip, and it also confirms I will never build anything with FTDI ever again.Kind regards,Cedric
Types 1-4 mean integrity checks on EEPROM addresses 0x40-0x4f failed (which seem to store manufacturer info, perhaps non-writable? haven't tried, the normal EEPROM user/config area is 0-0x3f), while type 5 does the good old 16-bit EEPROM writes check (what they used to brick devices in the previous version, except this time they revert their changes). It actually writes a 0 to the PID field (without fixing the checksum to match), reads it back, and restores it if written (original chips won't write it as its address is even).
I have used the FTDI FT232RL-REEL from farnell, order code 1146032. http://nl.farnell.com/ftdi/ft232rl-reel/ic-usb-to-uart-smd-28ssop/dp/1146032?ost=1146032&selectedCategoryId=&categoryName=Alle+categorie%C3%ABn&categoryNameResp=Alle%2Bcategorie%25C3%25ABnCould it be I have a counterfeit chip?
I am curious, that part number suggests a minimum order quantity of 2000 parts.
Well, since this is a not-seen-before behavior on the part of FTDI divers/chips/lookalikes
Quote from: westfw on March 22, 2016, 06:24:43 amWell, since this is a not-seen-before behavior on the part of FTDI divers/chips/lookalikeshttp://zeptobars.com/en/read/FTDI-FT232RL-real-vs-fake-supereal%20this%20deep-downKnown behaviour from more than two years ago. How old is his driver?
Quote from: Monkeh on March 22, 2016, 12:57:10 pmQuote from: westfw on March 22, 2016, 06:24:43 amWell, since this is a not-seen-before behavior on the part of FTDI divers/chips/lookalikeshttp://zeptobars.com/en/read/FTDI-FT232RL-real-vs-fake-supereal%20this%20deep-downKnown behaviour from more than two years ago. How old is his driver?What is known? Where you heard about sending zeroes, especially 2 years ago? In that link FTDI rep says they aren't going to send zeroes.
Fake chip was working kinda fine until FTDI released drivers update, which were able to detect fake chips via USB and send only 0's in this case.
