Author Topic: FTDIgate 2.0?  (Read 394543 times)
Offline filssavi
Re: FTDIgate 2.0?
« Reply #75 on: January 30, 2016, 07:12:43 pm »
interferance, bad connection and stuff are things that can happen just out of bad luck, and no one can be blamed for that
No, it is not a bad luck. It is poor design or poor implementation.
so you can abslutely guarantee that in any case and under any circunstance the product you will design will not fail if subjected to any pattern of connection/disconnection/reconnection cycles due to a bad connection or to any interferance whatsoever whitout ever causing a problem to the circuit???
if so why are you here talking and not making billions upon billions selling guaranteed EMI/EMP immune gear to the military forces of the whole world
the fact is that designing a reasonably safe product is doable, designing a guaranteed safe commercial (well even in 1 off quantity where you can forget the process variation and you can chose precise components) product is impossible, there always will be the corner case where the product will fail, also guaranteeing
that the failure will lead to any damage is not doable either
in the folowing pdf you can see a vast range of examples of failures due to EMI in NASA and other mainly US military gear and vehicles, since you said so we must conclude that NASA and others cited in this article don't know how to design electronic equipment
http://www.cvel.clemson.edu/pdf/nasa-rp1374.pdf
Offline dannyf
Re: FTDIgate 2.0?
« Reply #76 on: January 30, 2016, 07:15:38 pm »
"But they have no right to manipulate it either."
How do they "manipulate" it?
Again, for a group that often holds other people to the highest standard of morality, you collectively seem to have a very low bar for yourself.
Offline RFZTopic starter
Re: FTDIgate 2.0?
« Reply #77 on: January 30, 2016, 07:22:31 pm »
My Software is sending "YES" to my device and the FTDI driver converts it to "NON" being sent to my device.
What is it other than manipulation?
Offline zapta
Re: FTDIgate 2.0?
« Reply #78 on: January 30, 2016, 07:23:34 pm »
By intentionally modifying the data sent to the device and not informing the end user about it.
Offline filssavi
Re: FTDIgate 2.0?
« Reply #79 on: January 30, 2016, 07:28:30 pm »
"Except this time. Now a few thousand of your product are out there with fake FTDI chips, ..."
Why is that it is ftdis faulty that you have lax production control? Just because you cannot assure that the real thing is used in your products, some one else has to support it?
Does it sound reasonable to you?
so since is designer's/manifacturer's fault for not checking you can guarantee  and certify that you made shure each and every component you ever specified, active, passive or connector was genuine and that no product did not have any fake part whatsoever?
obviously just buying them on farnell/digikey doesn't count since it's pretty much established that in rare occasion (and not for their fault i'll say) they have sold fake parts (there is even a video where dave got burned from digikey)
Offline Refrigerator
  • Country: lt
Re: FTDIgate 2.0?
« Reply #80 on: January 30, 2016, 07:36:59 pm »
Wait, does this new driver say "Marco" and expect "Polo" from the original and if it gets nothing it refuses to work ?
How long will it take for the chinese manufacturers to mimic the original ? From what i know the fake FTDI has a mask ROM so all the chinese have to do is to change the mask ?  :popcorn:
I have a blog at http://brimmingideas.blogspot.com/ . Now less empty than ever before !
An expert of making MOSFETs explode.
Offline filssavi
Re: FTDIgate 2.0?
« Reply #81 on: January 30, 2016, 07:53:31 pm »
probably it'll be some kind of challenge and response mechanism (like ftdi driver send some random bits as challenge, FTDI chip, which is nothing else then a glorified special purpose microcontroller calculate a math function (most probably a hash of some sort) and then spits the answare back to the PC, so is a bit more complicated than just changing a couple of masks
that sais it's not that difficult to reverse engineer the function given enough time with enough math and silicon reverse engineering capabilities as you said i totally expect chinese to change slightly the design and make use of said driver...
DRM (to which this is related) has never, ever, ever worked, it might fend of random casual joe blog's kind of counterfeiters, but chineese industry is not that easy to fool...
Offline MT
  • Country: aq
Re: FTDIgate 2.0?
« Reply #82 on: January 30, 2016, 07:57:17 pm »
if someone kills a man he will be prosecuted
So if you drive over someone with a car, is it you or the CEO of Fiat that should be charged?
CEO of FIAT! Because they make so lousy cars!
A Japanese who was killed by the atom bomb once sued US government for dropping it.
Court later found that the Japanese should have sued the guy in the plane who opened the bomb bay doors.
Online wraper
  • Country: lv
Re: FTDIgate 2.0?
« Reply #83 on: January 30, 2016, 08:05:22 pm »
Most likely they were not fakes and Dave didn't say they are fakes. Most likely Digikey put a wrong part (5%) in the package as it wasn't a full reel.
« Last Edit: January 30, 2016, 08:07:37 pm by wraper »
Offline 0xdeadbeef
Re: FTDIgate 2.0?
« Reply #84 on: January 30, 2016, 08:05:40 pm »
There is no hint that this (not so) new driver uses a different approach than the older one from 2014 that bricked devices. The idea was (and probably still is) that the genuine chips accept only 32bit (2x16bit) EEPROM writes but some clones accept also single 16bit writes. So if the write succeeds, it's a fake. Or something like that.
Then again, even back then it was clear that only a part of the clones can be identified this way. I have dirt cheap FTDI based USB/UART interfaces from China with suspicious markings and a much too small and sharp pin 1 dent. Still they weren't and aren't identified as fakes.
Offline dannyf
Re: FTDIgate 2.0?
« Reply #85 on: January 30, 2016, 08:06:03 pm »
"My Software is sending "YES" to my device and the FTDI driver converts it to "NON" being sent to my device."
Ftdi driver does that because forbthe real thing to transmit "yes" it has to receive a "no". But the counterfeit chip doesn't understand that.
That's still ftdis fault?
Sounds like you know who the fault guy is. You are just refusing to acknowledge it.
Re: FTDIgate 2.0?
« Reply #86 on: January 30, 2016, 08:13:13 pm »
No, you got me completely wrong. As I confirmed in the second post in this thread, the FTDI driver makes a fake chip send "NON GENUINE DEVICE FOUND!" repeatedly for any character I try to send...
Sending "123" also gets converted to "NON" and "F*** OFF FTDI"  to "NON GENUINE " ...
Offline zapta
Re: FTDIgate 2.0?
« Reply #87 on: January 30, 2016, 08:19:54 pm »
Doesn't sound reasonable that the driver sends "NON GENUINE DEVICE FOUND!" to genuine chips. They intentionally manipulate the data the app sends.
If they would do it from day 1 it would be OK. Having a Windows update regressing working products is bad. Buying a FTDI based product is a long term risk.
Offline pickle9000
Re: FTDIgate 2.0?
« Reply #88 on: January 30, 2016, 08:26:06 pm »
I have a hard time understanding why there is such a pissy contest here: FTD is under no obligation to produce a driver that supports counterfeit parts. All you need to do is to make sure a) there is a driver for your counterfeit parts; or b) buy the real thing.
For a group that seems to denounce other people based on the slightest infringement of your moral high moral standard, you seem to have a very low moral standard for yourself.
I just don't have the time, using another part / solution is easier for me and my customers.
Offline Karel
Re: FTDIgate 2.0?
« Reply #89 on: January 30, 2016, 08:56:08 pm »
Nope, no risk at all. Buying a fake chip is a risk.
I don't feel pitty for people who buy cheap chinese (clone) products and start whining when it stops working.
Offline dannyf
Re: FTDIgate 2.0?
« Reply #90 on: January 30, 2016, 09:02:25 pm »
What's wrong with that? their driver isn't designed to work with counterfeit chips and god knows what dire consequences they could be if the counterfeit mis-behaved.
At the heart of the issue is if you think ftdi is obligated to support counterfeit chips. If you think 'yes', you have a (legal) Everest to climb in court, and gazillion $$$ to make off of suing FTDI.
Re: FTDIgate 2.0?
« Reply #91 on: January 30, 2016, 09:07:20 pm »
Once again (and for the last time), just not supporting a fake chip is fine, making it send manipulated wrong and potentially harmful data is not.
Offline dannyf
Re: FTDIgate 2.0?
« Reply #92 on: January 30, 2016, 09:25:24 pm »
why? To borrow, "what difference does it make?"
When you are actually damaged from such wrong data, you may have a standing to sue. Until then, you are out of luck.
Online Ian.M
Re: FTDIgate 2.0?
« Reply #93 on: January 30, 2016, 09:36:07 pm »
FTDI could have just written a driver which randomly drops approximately one byte in N if a non-genuine chip is detected.  Start off with N fairly high and decrease it towards 1 in 1000 over time.   Result: fakes and clones get a reputation for being flaky.
If they'd done that originally, FTDIgate would never have happened and they'd still have a reputation as a premium brand for USB connectivity, instead of driving many smart developers to consider alternative chips.
Offline dannyf
Re: FTDIgate 2.0?
« Reply #94 on: January 30, 2016, 09:38:58 pm »
The safest way to avoid fake parts in your product is not to buy jelly bean parts.
I think if you avoid ebay and Chinese parts, you have eliminated 99% of the chance of getting con'd.
Cheap parts are expensive in the end, as the old saying would have it.
Re: FTDIgate 2.0?
« Reply #95 on: January 30, 2016, 09:44:37 pm »
Yeah right, great idea  |O ... Intentionally manipulating computer data / systems can be considered crime, regardless if the device is yours or fake.
Once again. Just imagine Microsoft would randomly delete some bytes of the files you create on PCs with a non genuine licence...
Offline rs20
Re: FTDIgate 2.0?
« Reply #96 on: January 30, 2016, 09:55:03 pm »
You know, we can debate the legality (yes), morality (no) and stupidity (yes) of FTDI's decision all we want; but it's all irrelevant because these are the death throes of a company rendered obsolete by the availability of US$0.62 MCUs with USB built in... It's not as if Windows doesn't have a CDC class driver built in that can be referred to by a simple text INF file. The driver in question doesn't care who made the chip! It hasn't been seen to corrupt customer data, not even once!
This company used to be based on a real need; now it's staying afloat due to sheer laziness of designers who would rather spend dollars and board space on a problem that can now be solved with a #include. I used to be one of those designers until the first "FTDIgate", it was just the wake-up call I needed because now my designs are smaller and cheaper! Thanks FTDI!  :D
Online wraper
  • Country: lv
Re: FTDIgate 2.0?
« Reply #97 on: January 30, 2016, 10:01:36 pm »
No, FTDI would get a reputation of being flaky. Before FTDI, the most popular were Prolific chips. Counterfeits worked unreliably with the new drivers computer could even catch a BSOD with them. Needless to say, for most of the people it appeared that Prolific chips were crap, not that they have bought a counterfeit.
Offline rrinker
Re: FTDIgate 2.0?
« Reply #98 on: January 30, 2016, 10:45:53 pm »
 Does it sound reasonable to you that someone's device is ruined by the driver? The buyer had no clue a fake FTDI chip was used.
I don't think anyone here would have a problem if it simply did not work if a fake FTDI chip was detected. No writing back to the device in a way that destroys it, no altering the communications. Just - doesn't work unless a genuine FTDI chip is used. That's entirely within FTDI's rights. Intentionally damaging a device is over the line.
Offline pickle9000
Re: FTDIgate 2.0?
« Reply #99 on: January 30, 2016, 10:52:54 pm »
No argument here.
