Author Topic: FTDIgate 2.0?  (Read 231975 times)
Offline mtdoc
Re: FTDIgate 2.0?
« Reply #425 on: February 04, 2016, 02:03:20 pm »
There's only 0.01% counterfeit currency in circulation. Yet there what like 6 tiers of anti-counterfeit technology built into our bills now?
Exactly. The effort goes into making the technology harder to copy. i.e. Innovation. If FTDI can't innovate their way out of the clone problem by competing on price or features- too bad - they fail. Unfair? Perhaps but that is the way the market works.
Because it's hard to detect fakes we shouldn't bother to do something about it?
Another Strawman. No one said that. The question is how best to respond.
I have a way. Buy from real vendors. You pay more money for the insurance you are getting real products. Personally, 5 figures worth of units and no fakes. I have yet to see an example of Digikey selling counterfeit FTDIs. And if they did, I be dam sure they replace the fake stock at no cost.
And once again you fail to acknowledge that thei issue is that it's the end users being affected, not just those buying components for manufacturing.
Offline zapta
Re: FTDIgate 2.0?
« Reply #426 on: February 04, 2016, 02:29:50 pm »
What the FTDI apologists continue to ignore ...
That labeling of people that don't share your opinion cancels everything you are saying because you are not being objective.
+1
No need to lower the debate with personal labels.
Drain the swamp.
Offline miguelvp
Re: FTDIgate 2.0?
« Reply #427 on: February 04, 2016, 02:34:37 pm »
it's a descriptive term. I'm open to suggestions for an equally concise term to refer to those who try and justify FTDI's actions
Huh, it's more than a descriptive term and obviously not taken at random, do not insult also my intelligence and comprehension of the human factor.
I mean, "Apologist" on your use it's a combination of defender and apologizing on someone else's behalf with a demeaning connotation touch to it.
Very carefully selected.
a convenient way to dodge the issues I raise.
Not at all, you said:
What the FTDI apologists continue to ignore is the fact that consumers have no way of knowing the product has a fake FTDI chip in it beforehand and are being harmed by FTDIs tactics if it does. This is causing the people who make the choice of what chip to use in their product - choose other chips. FTDI claims to be targeting the cloners but continues to shoot themselves in the foot.
And I did reply this as well which you have not included:
Let's be clear about what the driver does and doesn't, your PC sends characters and the driver echoes the "NON GENUINE DEVICE FOUND!" character by character as you try to communicate with the device.
Even if the device receives those strings it would be a pretty poorly designed protocol that blindly accepts anything without initialization and exchanging some initialization handshakes to make sure the device is communicating with the appropriate piece of software running on the PC, otherwise any other program can hijack the COM port and create havoc.
I think it's a valid implementation from FTDI part to protect their hard work.
Claiming that a lot of devices are affected by this? well then they should return them to whoever was careless enough to use fakes, and I don't buy it that they are victims, they are purchasing the cheapest offerings on purpose, so it's their fault for promoting unfair competition and theft.
What if you buy an expensive piece of kit, you check it and it has Rubycon caps on the power supply so you feel really good about it, but they happen to be fake and shortly after a year and your warranty expiring, they start leaking. Who are you going to blame?
Buy go ahead and promote piracy all you want.
Strawman. I've seen no one justifying piracy. The issue being discussed is what is the appropriate response to piracy? Who's  not being objective here?
Hmm Strawman... is that you Mojo? he used it a lot.
kidding aside, look at what you didn't quote me on, I did address that I think (In My Opinion, to be clear) that FTDI did the right thing and their response on their second approach is a good response to the issue at hand.
Clearly the consumer doesn't even know what FTDI is or means, maybe a flower delivery service, their device stops working they call the manufacturer since they are the ones that made the product.
The message that comes across from you, even if you have mentioned many times that you are against counterfeit products is that you are indeed blaming companies that are trying to do something about it.
No, what I am saying is that FTDI's tactics have been misguided and self destructive. I think what these responses by them show (including their response to Dave on Twitter) is that this area of their business is failing. The reason likely has little to do with the clones but instead is largely due to the availability of better alternatives as you yourself and others here have pointed out. If I was an investor in FTDI, I would take these episodes to be a sign to get out.
Yup, their first approach was harsh and they did deserve the heat.
This time around, I think they are on their right to not support non-FTDI components and associated support costs.
If some device stops working I contact the manufacturer I don't go to the chip and contact the chip maker.
Why should FTDI allow their driver talk to non FTDI chips? just because they did before? that's not reason enough (In my opinion again) if it's hurting their bottom line.
It's their property (the driver that is) so they are free to do what they want, will it end up hurting them or helping them, I'm pretty sure they are monitoring that. As for twitter etc, it's normal for a company not to stir things up, because the vocal minority will amplify their voice while the silent majority doesn't care at all.
« Last Edit: February 04, 2016, 02:37:16 pm by miguelvp »
Offline amyk
Re: FTDIgate 2.0?
« Reply #428 on: February 04, 2016, 02:37:19 pm »
That's fine. But dumping trash data or frying chips are not fine.
And making counterfeit chips or otherwise ripping off FTDI's IP is fine? Maybe in China, but not where I'm from.
Sure, FTDI took the nuclear option here, but I think they're completely justified in doing so.
Cloning die is a big no go. Cloning protocol, as long as it was not patented, is fine at least in China. But you CAN NOT put FTDI logo on the chip, of course.
Actually...
https://en.wikipedia.org/wiki/Semiconductor_Chip_Protection_Act_of_1984
...copyright of the layout, i.e. the masks, only lasts for 10 years, at least in the US. I think the FT232s are more than 10 years old now... also, from the article:
The SCPA permits competitive emulation of a chip by means of reverse engineering.
More food for thought: the only difference between an illegal and legal clone is whether or not there is the FTDI logo on it, which is something the driver cannot determine at all. And if copying a much longer piece of code that is required for interoperability is legal, a VID:PID pair is likely to be as well. Even if FTDI tried to twist it into some sort of trademark protection by e.g. making the chip respond with "this is a genuine FTDI device", that probably won't work either: https://en.wikipedia.org/wiki/Sega_v._Accolade
Offline madsci1016
Re: FTDIgate 2.0?
« Reply #429 on: February 04, 2016, 02:48:47 pm »
Though none of this says FTDI must be forced to write working drivers for devices it doesn't sell. I agree bricking devices might violate the spirit of these court cases, but refusing to work with non genuine hardware doesn't.
Offline mtdoc
Re: FTDIgate 2.0?
« Reply #430 on: February 04, 2016, 02:58:28 pm »
Yes that is the definition.
No, not part of the definition - that is your judgement of my use.
Again -I'm open to suggestions for a different term. It seems apt and descriptive since it means exactly what you say.  Of course there is a judgement by me associated with it in this case - that is a judgement that the defending and apologizing is unjustified.
It is not meant as a personal attack at all - in fact I have not used it directed at you or anyone specifically - just to concisely refer to those who are - well - apologizing for and defending FTDI's behavior.
To be honest - I have a lot of respect for you miguelvp based on your history of posting here you are knowledgeable and non ideological. If you have taken any of my arguments personally - I apologize.
Valid? perhaps. My argument continues to be that it is misdirected and foolish.  That's all. It's not a personal attack on you or anyone else.
What does "careless enough to use fakes mean"  are you saying the average electronics hobbyist who goes on eBay and searches for USB serial converter is being careless? how are they supposed to determine which have fake chips?. And no price alone is not enough to make that determination.
Now that qualifies as a personal attack!. ;D  I'm disappointed. BTW strawman is a commonly used term by many on this and other forums - you realize that I'm sure.
I didn't quote that because it's just a different opinion - not a point of fact to debate.
On that we agree- This most recent approach is still foolish IMO but less bad I agree. In general in this thread though I think the topic has been about their overall approach to this issue - including both attempts go after the fake chips.
In addition, the recent blocking of Dave and others by FTDIChip on Twitter just further reinforces my opinion that their management is completely inept and out of touch.
« Last Edit: February 04, 2016, 03:16:07 pm by mtdoc »
Offline boffin
Re: FTDIgate 2.0?
« Reply #431 on: February 04, 2016, 03:33:47 pm »
Interesting.  New Firmware release today...
http://www.ftdichip.com/Drivers/VCP.htm
Boffin at play https://snafu.ca/
Offline miguelvp
Re: FTDIgate 2.0?
« Reply #432 on: February 04, 2016, 04:26:27 pm »
I wonder if they changed the string to only go to the PC and not the device?
Or have they succumb to the internet pressure of the vocal few?
I don't have any FTDI chips, clones or not, then again I don't have any xxxduino in here, but maybe I do but if I do, it's probably the real deal.
Nope, I did a "driverquery" on my command prompt and no sign of FTDI.
Offline blueskull
  • Country: cn
  • Power Electronics Guy
Re: FTDIgate 2.0?
« Reply #433 on: February 04, 2016, 04:37:48 pm »
Did a string search in their binary, the notorious "NON GENUINE DEVICE FOUND!" string still exists.
Offline filssavi
Re: FTDIgate 2.0?
« Reply #434 on: February 04, 2016, 06:20:54 pm »
I would like to know if anyone thinks here that what they are doing here is anything more than just a personal vendetta...
By that i mean, the non genuine string (and even the bricking stuff) will not make cloners abbandon the market, it will only prompt them at better emulating the real FTDI ic's to pass the f****in check, and even if it did, what would it bring in FTDI's bank account
It' like thinking that when the police seizes a batch of fake handbags, that would have ben sold for 50€, the clients not finding the clone will go at the Hermes shop and drop 20000€ on a real one. It's not happening, the client will find another fake handbags they like...
I mean piracy is a social/commercial problem, you can't solve it by shouting, yelling and punching people
The core problem here are 2:
-the IC price out of touch with reality, so cloners can undercut the price and still have huge margins
-FTDI is fading out of market by mean of shear obsolescence of their products, even the smallest mcu's have usb in them and the market for USB/serial is disappearing.
So if for a healty company cloners are annoying but inevitabile for FTDI they are an existential threat due to the incompetance of the management
Offline Karel
Re: FTDIgate 2.0?
« Reply #435 on: February 04, 2016, 06:26:38 pm »
That's your opinion and the opinion of some others, mostly hobbyists who got burned by buying cheap (Chinese) products.
In a professional environment, this plays no role, apart from the fact that you have to check your sources, but a professional
already did that.
Aim your anger to the counterfeiters, not to a a company that tries to protect their investment by not supporting
counterfeit chips with their driver. There's nothing wrong with sending the string "this is not a genuine chip" when counterfeit
is detected.
The difference between theory and practice is less in theory than
the difference between theory and practice in practice.
Expensive tools cannot compensate for lack of experience.
Offline Karel
Re: FTDIgate 2.0?
« Reply #436 on: February 04, 2016, 06:31:54 pm »
That's up to FTDI to decide what's best for their interest. I guess they have done some estimaton about this.
Apparently, they think it's better for their business by doing so. As long as they don't break any law, it's completely up to them.
Offline Gribo
Re: FTDIgate 2.0?
« Reply #437 on: February 04, 2016, 07:35:24 pm »
I just got an evaluation board from NXP (PNEV512B) which contains an FTDI FT232RQ device. Guess what? VID is 0. Thanks to FTDI and NXP I lost an hour of my life.  :--
Offline westfw
Re: FTDIgate 2.0?
« Reply #438 on: February 04, 2016, 07:42:27 pm »
Has anybody here purchased any FTDI device from a legitimate distributor in the last, say, 6 months and received a fake?
Does anyone have an Arduino Nano that doesn't have a counterfeit FTDI?  There were hints that even the original (Gravitech-manufactured) boards might have had fakes - people who had bought full-price Nanos from trusted distributors were getting their chips bricked back in 2014...
Offline pickle9000
Re: FTDIgate 2.0?
« Reply #439 on: February 04, 2016, 07:43:09 pm »
already did that.
is detected.
The real issue is that the decision to "play" with the driver brings attention to the counterfeits. I agree that they have every right to do so (within reason).
For myself and my customers I would opt not to use a potentially counterfeit device in future designs. There are many other choices out there and I'd move on to the next device. This is not a supply issue just another criteria used on a BOM.
Offline station240
Re: FTDIgate 2.0?
« Reply #440 on: February 04, 2016, 07:46:50 pm »
I've just discovered some of the Ti evaluation/dev boards with onboard JTAG programmer (USB), use a FTDI FT2232D as the device.
$8.53 each in FTDI's shop, or 100 for $633.08, plus crappy exchange rate and postage. Now I have to wonder if FTDI's 'special' drivers* will screw with JTAG programmers, looks like I'll have to ask Ti for help as I would like to have onboard JTAG to USB in my PCB designs.
* special in that no one else is pulling this sort of shit.
« Last Edit: February 04, 2016, 07:58:13 pm by station240 »
Offline miguelvp
Re: FTDIgate 2.0?
« Reply #441 on: February 04, 2016, 07:58:12 pm »
That's hardly a company (well companies now) using legitimate distribution channels, actually as one of the companies was concerned they were the only place to produce the Arduinos.
I think people that have fake chips on their xxxduinos should complain to the manufacturer to make things right, after all it's bad karma to build a business based on someone else's (a student) hard work like the duino folk did.
Offline janoc
Re: FTDIgate 2.0?
« Reply #442 on: February 04, 2016, 10:07:41 pm »
already did that.
Wow, Karel, I wouldn't want to work for the customer support of your company if your engineers have this attitude! You think that the Intel folks who had to deal with the support request because of the fake adapter work for free or what? Someone has to pay for the wasted hours! And that was a stupid error message on a hobbyist's product, now imagine if a production line stops because of a monitoring PC with Windows XP that has been updated and now spews garbage into a PLC. We are talking hundreds of thousands of euro of lost money because of this.
You have obviously no idea about what it takes to support a commercial product and the nightmares you get - even if you did all due dilligence and this sort of thing is not really your fault - you still get blamed, because the client doesn't (and shouldn't) care!
Our company doesn't build machinery but we build simulators for it to train operators - and have to regularly deal with issues such as PLC that controls the simulator control panels stopping to talk to the rest of the system because some stupid driver got updated behind our back or someone thought it was a good idea to replace a cable. The PLCs use serial ports, so these USB to serial adapters are common. Who do you think gets called when a guy at a factory in Mexico has a problem starting the simulator in the morning? (which is late evening here in France)?
Do you know how much money does all this cost? Both in direct costs (money to pay the engineer to do the actual support and troubleshooting) and indirect - because our product is seen as "broken and never working right", even though the problems are in 99% of cases nothing to do with us - bad cables, unplugged components (yay, cleaners), flooding (yay, facility management), fried equipment because of power surges (yay, someone was too cheap to put in a surge protector despite our explicit advice), etc.
Yes, poor design, people opting for cheap solutions, etc - but one rarely has the luxury to control all of this in real world. If the client decides to do something against your advice, you can't do much there. Also you cannot demand that the PC used for the system is never updated or network connected. That's just not reasonable thing to ask, especially when your product is mainly software and depends on good functioning of the PC (i.e. no viruses, malware, etc.)
We have never bought any of USB to serial adapters ourselves, it is usually the client who supplies the same hw as they are using for production, so how can I guarantee that the supplier didn't ship one with a counterfeit chip with the PLC? Or that even the ethernet enabled PLC doesn't have a fake chip inside? Counterfeit parts were discovered even in airplanes (both Airbus and US military), where the supply chain is much more strictly regulated than for a $10 computer part.
Their supplier likely doesnt have an idea what is in those cables neither because they just got them from Siemens or whoever their vendor is. But it will be us as the integrator who gets hit with the support calls and costs, not Siemens! Siemens will at best replace the cables/PLC, the rest of the expense is out of our pocket. In that situation, a vendor going rogue and doing what FTDI is doing now is just a nightmare. Are we impacted? If yes, how much? What could fail? Where?
Reality doesn't often match with whatever the armchair critics dream out. Some of this can be covered by the contracts (aka client gets billed), but it is still wasted time debugging the problem. That you haven't seen these problems doesn't mean they don't exist but that you should get out of your chair and broaden your horizon before making a fool of yourself.
« Last Edit: February 04, 2016, 10:33:26 pm by janoc »
Offline madires
  • A qualified hobbyist ;)
Re: FTDIgate 2.0?
« Reply #443 on: February 04, 2016, 10:58:17 pm »
It's entertaining to watch the FTDI apologists twist and turn to justify FTDI's tactics.
The bottom line remains the same: People who unknowingly bought products with fake FTDI chips are being harmed and FTDI's actions are alienating their own customers.
They are being outdone by other companies with competing products and their actions regarding clones, whether justified or not, are only exacerbating migration of their customers to those alternatives as well as generating a feeling of ill will towards the FTDI brand.
Yes, that's excatly how the market works. If FTDI is so concerned about fake chips they shouldn't publish their Windows driver and provide a driver SDK to their customers. So any company building some product with a FTDI chip can get their own USB ID and ship the product with a dedicated driver. The way FTDI deals with the fake chips at the moment is simply :palm:
Offline AlxDroidDev
  • Country: br
    • Arduino Web Brasil
Re: FTDIgate 2.0?
« Reply #444 on: February 04, 2016, 11:00:52 pm »
That's completely childish, to say the least. FTDI has made a fool of itself and it continues to do so. They are even worse than the Fine Brothers!
I just wonder if someone from FTDI actually reads these forums. I suspect 1 or 2 members here might be FTDI employees, because of how adamant they are in defending FTDI and their crappy business.
"The nice thing about standards is that you have so many to choose from." (Andrew S. Tanenbaum)
Offline madires
Re: FTDIgate 2.0?
« Reply #445 on: February 04, 2016, 11:05:07 pm »
bricking my chip was a really bad move,
I am sure FTDI has a different perspective: they wrote a set of procedure that works flawlessly on the genuine chip. You happen to plug your fake chip there and ...
That's called computer sabotage and is an offence in several countries, in case you don't understand the implication of bricking someting on purpose.
Offline dannyf
Re: FTDIgate 2.0?
« Reply #446 on: February 04, 2016, 11:10:35 pm »
"Did a string search in their binary, the notorious "NON GENUINE DEVICE FOUND!" string still exists"
Would be interesting to see how it rracts to a knock off. Ie. The code may be there but it may not actually run.
I have quite a few arduino boards, mostly the Leonardo and the minis. The first thing I do with them is to wipe out the bootloader as I program them as avr boards.
Offline FrankBuss
    • Frank Buss
Re: FTDIgate 2.0?
« Reply #447 on: February 04, 2016, 11:20:45 pm »
I think this is very likely. JTAG is a feature of the D2XX driver. If I configure the D2XX driver with FT_Prog (you can use this program to read your configuration), then it uses the driver ftdibus.sys, which contains the string "NON GENUINE DEVICE FOUND!". Interestingly if I configure it as "Virtual COM Port", it uses ftser2k.sys, and ftcserco.dll and ftserui2.dll, which don't contain the string.
Looks like a mess for me with all the different drivers, but this might be a problem of Windows that you can't use just one driver, if you want a virtual COM port and then other special things.
Offline rrinker
Re: FTDIgate 2.0?
« Reply #448 on: February 05, 2016, 01:29:57 am »
 Mine's fairly well stuck in the breadboard I have it plugged in to so I can't see the bottom to see what brand the chip is marked as, but if it's a fake FTDI, it's still working perfectly fine and my system is a fully up to date Windows 10 machine - works on my laptop as well. I wouldn't be surprised if mine actually has a knockoff of a knockoff USB chip, considering I paid like $6 for this Nano from Amazon.
Offline blueskull
  • Country: cn
Re: FTDIgate 2.0?
« Reply #449 on: February 05, 2016, 02:26:57 am »
I do not have a fake FT232, so I can not test it. I do not have time to reverse engineer the code either.
It works with my genuine FT2232H with no problems (I would be very surprised if I got a fake FT2232 since I got the module from DigiKey made by FTDI themselves).
