They are connecting a sensor with I2C/SPI/UART/whatever interface and use Arduino USB port for serial communication.
No, you won't. There is no RX and TX in USB. You can connect PS/2 keyboard, but that's probably not what you want.Also, you don't just get results on the serial port, you need to write firmware to do so.
