Author Topic: Hardware revision + unique serial IC's !!??  (Read 3596 times)
Offline dav888Topic starter
  • various artists
« on: September 20, 2018, 03:04:15 pm »
I'm dreaming of an IC that is a combined QR-code and Hardware revisioning tag.
Anyone knows if this exists!?
There are cheap temp-sensors with i2c and unique serials, and there are passive laser-etched tags with some sort of qr-code on them...
but what I'd like is:
  • QR-Code with unique counter
  • I2C to read-out that same QR-code
  • 4 gpio's to tie to GND or VDD for indicating Hardware revision (also read via I2C)
Thoughts??
Online JPortici
Re: Hardware revision + unique serial IC's !!??
« Reply #1 on: September 20, 2018, 03:08:31 pm »
mm.. ST makes I2C EEPROMs with a 128 byte OTP area, so you can write there your serial number, hardware revision and all other info that must not be erased or altered
(i do this when i'm not using dsPICs which have a dedicated OTP area on chip)
no idea about the QR code, though
Offline Ice-Tea
    • Freelance Hardware Engineer
« Reply #2 on: September 20, 2018, 03:12:06 pm »
Not sure what your preocupation with QR codes is? That's just another way to represent a string of data, in this case a serial number?
Offline Ice-Tea
« Reply #3 on: September 20, 2018, 05:10:45 pm »
He wants a QR code etched on the molding, so you can scan it.
Oh!
OK. That makes sense. Kinda. Would need quite a bit of surface on the chip to make it big enough to scan, though...
Offline dgtl
  • Country: ee
« Reply #4 on: September 20, 2018, 06:30:11 pm »
I've used 1-wire chips for identification. There are some with parallel inputs, that you can use for board revision (DS28E04-100).
I've not seen any with the number on the case; it would probably not be readable with a scanner anyway. Read it out electronically.
Another idea would be using the dynamic RFID tag chips. It acts like an RFID/NFC tag, but has additional I2C interface. Use an NFC reader to scan the tags.
Online PA0PBZ
« Reply #5 on: September 20, 2018, 06:52:03 pm »
I'm not sure OP wants the QR code on the chip itself.
Offline ajb
« Reply #6 on: September 20, 2018, 07:42:12 pm »
The other option is to print QR code labels, then as part of the initial board config scan the QR code and load the data into your NV memory.  The QR code labels can include version info if you want.
Offline AloyseTech
« Reply #7 on: September 20, 2018, 08:55:32 pm »
Some microcontroller development board have either an internal unique ID or an external I2C ID chip (basically a 128bit unique identifier which is garantied by manufacturer). It is also common to see laser-etched QR code on mass produced PCB. I don't know if it is a unique QR code though.
Offline donotdespisethesnake
  • Embedded stuff
« Reply #8 on: September 20, 2018, 09:13:51 pm »
What happens if programming the NV memory depends on the hardware revision?
I would settle for a unique id + configurable hardware id, but a QR code on the IC as well would be pretty neat.
Bob
"All you said is just a bunch of opinions."
Offline djacobow
  • takin' it apart since the 70's
« Reply #9 on: September 20, 2018, 09:16:45 pm »
I can see the benefit of a chip that can be read electronically, by eyeball, and optically by machine, but I agree that the latter necessitate something large that is not going to price/space friendly.
I think what is commonly done in manufacturing environments is that as part of the program/test plan, a decal is generated with serial number read off the chip on it. The decal can then be applied to the box, the outside or inside of the case, and stored on a computer.
I worked for an IoT company that did this. When configuring the product, the end user had to enter the code on the box which was a hashed version of the serial. This meant that someone else couldn't easily reconfigure your hardware. And when the device phoned home the first time, that value was compared with what we had on file to keep coutnerfeit hardware off our systems.
Offline ejeffrey
« Reply #10 on: September 20, 2018, 10:44:05 pm »
The idea sounds cool but I think it doesn't have much of a market.  In large volumes labels are going to be cheaper and more flexible.  Presumably whatever project this is already needs to be tested and flashed as part of assembly.  Adding label printing to the assembly process is trivial.  The advantage here is that the label can be any size and location.  This can be on the edge of the board away from components or on the enclosure so the user can read it without opening.
Offline ajb
« Reply #11 on: September 21, 2018, 02:54:23 pm »
The same thing that happens when you bring up a device for the first time normally?  If you're doing field/OTA updates, then sure, you want the device to be able to intrinsically know who and what it is whenever it wakes up, but when doing the initial configuration, you presumably know what device is on your bench or on your production line, so you flash the board, tell it what it is and what revision, and whatever else it should store in its NV contents.  If you need to unequivocally know the hardware revision, then you can continue to use pin strapping on the board itself.
Offline TomS_
« Reply #12 on: September 24, 2018, 03:42:27 pm »
Maxim DS2431+ is a 1-wire, 1kbit EEPROM with a 64 bit factory set unique ID that cannot be altered (I believe it is laser etched).
Though that doesnt satisfy the GPIO requirement, theres no particular reason you couldnt store the HW version in a byte of the EEPROM and read it out, along with the 64 bit unique ID?
But as with most Maxim stuff, they arent cheap.
Offline brabus
« Reply #13 on: September 24, 2018, 04:08:08 pm »
Not really sure if the OP knows what a QR Code is, though...
  • various artists
« Reply #14 on: December 30, 2020, 10:43:47 pm »
we usually print or laser the QR codes today, min size that works seems to be 4*4mm
so the chip I want 8) could be 4*4 bga or qfn style.
a cool additional feature for it to make more sense would be a set of say 4x gpio's
this way you could easily define your board revision or bom-config by simply pulling the ones for that revision to gnd
Offline gussy
« Reply #15 on: December 31, 2020, 10:45:30 am »
Molex actually made a "chip" with a unique QR code etched on top: https://www.digikey.com/en/product-highlight/m/molex-connector/track-it-traceability-pad
It looks like they EOL'd them in the last few years though. Not surprising given their cost compared to a QR code sticker. Every CM that I've ever worked with, large and small, has been completely capable of printing and placing small QR stickers for PCBA traceability.
If the molex parts actually did something active, like being having some EEPROM and the serial number on I2C then it could be more interesting, but they were essentially just expensive QR code stickers that a PnP machine could place. :-//
Offline fchk
« Reply #16 on: December 31, 2020, 11:36:20 am »
Would RFID also be ok?
ST has EEPROMS that have both I2C and RFID:
https://www.st.com/en/nfc/st25-dynamic-nfc-tags.html
fchk
Online mikeselectricstuff
    • Mike's Electric Stuff
« Reply #17 on: December 31, 2020, 11:48:13 am »
I think your best bet is a QR code label, which gets read and programmed into an eeprom as part of the production test process. Or depending on your process, maybe a unique ID (from an MCU or other serial-number device) that gets printed onto a QR code label in production.
Microchip sell EEPROMs with unique MAC addresses : https://www.digikey.co.uk/product-detail/en/microchip-technology/24AA02E48T-I-OT/24AA02E48T-I-OTCT-ND/2003468
A standard SO8 I2C EEPROM can give you 3 inputs for hardware version - the address pins, but you could probably also porgram the HW version as part of the above production programming step.
Day Job: Mostly LEDs
