Have an ARM chip with 128K RAM, I almost certainly have enough for anything I’ll want to do but not entirely certain and I don’t really have a say to solve my problem that I like.
Scenario is I have a stream of data coming in. It could be 20 bytes to 2,048 bytes. I need the entire stream received, block decrypt it, then store it for another function to use. There are 10 types of data that can come in and while i can only handle one “7” type at a time, I could handle a “3” and a “7” concurrently. If a “7” comes in while I’m working on a “7” I ignore it. Further complicated that “6” “7” and “8” types can not run concurrently, so they “could” share memory.
Problem is, I either statically allocate 20K or RAM in 2K chunks which seems very wasteful as most data blocks will be far less than that 2,048 worst case, I use malloc() and free() carefully, or I try and manage the memory myself by declaring a block and allocating and freeing from inside that manually.
Am I missing an obvious option?
I read a lot of malloc() hate for embedded but it would make things seem clearer.
