Author Topic: Help! adapting a SCN2661in Grant Searle z80 design  (Read 8549 times)
Offline ali6x944Topic starter
  • Country: sa
Re: Help! adapting a SCN2661in Grant Searle z80 design
« Reply #25 on: November 10, 2016, 04:05:03 am »
So do I have to falsh the rom to operate the EPCI?
As the cpu have to adress them, I mean the programming pins /CE,A1,A0,/R,W
  • Country: sa
« Reply #26 on: January 23, 2017, 07:52:55 am »
I will try to right on the rom, until now I don't know what to fill the rom I will search in the datasheet about any info that might be helpful...
Offline Bruce Abbott
    • Bruce Abbott's R/C Models and Electronics
« Reply #27 on: January 29, 2017, 09:53:23 pm »
To use the EPCI with Grant Searle's ROM You will have to modify the source code in 'intmini.asm'. If you don't get it exactly right then it almost certainly won't work, so when you have built the circuit and written some code post it here for us to review.
The following users thanked this post: ali6x944
