Hello, im stuck in a project, i need to save a firmware on a flash memory, the firmware file is in .raw format and the flash memory to be programmed to is the M28W320FCB70ZB6E chip, but i cant find any programmers compatible (well at least on the device list it does not appear this chip),
Any suggestions? as always i would prefer the cheapest one but as i want a durable one maybe we can find one stuck in between.
Thank you in advance.
