Author Topic: Help with Altera Cyclone III configuration problems.  (Read 3749 times)
Offline BoscoeTopic starter
« on: April 04, 2015, 12:49:00 pm »
I've tried to make a development board for the Cyclone III, most of it works as far as I can tell without the FPGA.
My problem is with the FPGA configuring after I have successfully downloaded the configuration file to the serial memory. Referencing this document:
https://www.altera.com/en_US/pdfs/literature/hb/cfg/cfg_cf51001.pdf
I can tell what stage the FPGA is in when powering up. Well nothing happens. The FPGA just sits there with NCONFIG at 1.5V, CONFIG_DONE at 0V and NSTATUS at 0V.
I think there may be something wrong with the FPGA as NCONFIG isn't at 0V, when I pull it low to reset the device and attempt to restart the configuration it drops a little to 1.2V.
I have gone over the pins and connection scheme and unfortunately haven't found any problems!
Attached is my schematic, it has some errors but I have made a rev1.1 schematic and changed those. One of those is the schematic says I'm using 1MB of memory when I'm using 16MB. I show rev1.0 as this is the revision of the board I'm working on.
Thanks for any help!
Offline Scrts
  • Country: lt
Re: Help with Altera Cyclone III configuration problems.
« Reply #1 on: April 06, 2015, 09:00:59 pm »
NCE is pulled low by 10k. I think it has internal 10k pull-up. Pull that hard to GND with 0Ohm.
« Reply #2 on: April 07, 2015, 01:54:19 pm »
Thanks for your reply. It is pulled low in the schematic however I replaced the 10k with 0R and no change.
I decided to test whether the pad on the bottom had continuity to GND and it didn't so I fixed that and the FPGA configures from the memory however now Quartus Programmer does not recognise the memory when the pad is connected to GND. It works when I lift it.
Offline Scrts
  • Country: lt
« Reply #3 on: April 07, 2015, 02:52:01 pm »
Can you program the FPGA using JTAG? Does CONF_DONE go up then?
« Reply #4 on: April 08, 2015, 12:41:19 pm »
Unfortunately I didn't bring the JTAG out and I can't mod it. :(
Do you have any other ideas?
I haven't had time to look at it since I got it working a bit. I have time tonight and see if I can solve it.
Offline deephaven
  • Civilization is just one big bootstrap
    • Deephaven Ltd
« Reply #5 on: April 08, 2015, 12:51:40 pm »
Have you got MSEL 1, 2 and 3 set appropriately? See https://www.altera.com/en_US/pdfs/literature/hb/cyc3/cyc3_ciii51016.pdf
I have MSEL 2, 0 connected to 0v and MSEL 1 connected to Vdd.
« Reply #6 on: April 08, 2015, 07:56:01 pm »
Yes, that's how I've got them.
My problem is with nCE. When lifted Quartus downloads the data to the config device fine but the FPGA doesn't configure. If I then ground nCE, it configures and works but I can't download anything.
« Reply #7 on: April 08, 2015, 08:01:04 pm »
Okay I've got everything working now. It was because I shorted nCE to ground but in the app note it says to pull it to GND via 10k.
