Just a quick update and cry for help.
TLDR: I need a ~50MHz time interleaved ADC clock generator.
After much research we have decided that we need to sample at approximately 32Mhz (based on the bandwidth of our sensor) for about 1 second (the maximum duration 95% of lightning strikes)
. The memory requirements thereof are astronomical, requiring 32 MSamples, at, as per project requirements at >12bits (preferably 16bits) per sample, this means an overall memory requirement of at least 512Mbits (64MB) !!!!!
At this point any pre-built oscilloscope meeting these specs or similar equipment are far beyond our moderate student budget. In order to achieve these requirements it was deemed economical to time interleave four ADC's, as at most 128Mbits of FIFO can be easily attached to each ADC.
Now the design thereof was going smoothly until I realized that I needed to provide these ADC's with time interleaved clock signals
. I have tried to search for an IC that accomplishes this, however most of these IC's are designed for time interleaving of clocks in the 100Mhz-1Ghz bandwidth (LMK03000, AD9512 etc). As a result they come with a hefty price tag, and in a package that will be near to impossible to to both solder and create a board for, without much more expense.
In short I am wondering if anyone here knows of a rather simple IC or circuit that may achieve this time interleaved signal?
Thanks for your time.
