linux embedded platforms change too fast (too many new ones come out and old ones get EOLd quickly) - so I would not recommend embedding linux IN a product.
Nonsense. Lots of ARM SoCs from TI and Freescale will be available for at least 10 years.
I think you are not talking about the same thing, guys.
Linux-works is talking about Linux
boards (i.e. something like Raspberry Pi, Beaglebone, Gumstix ...) and those do, indeed, change quickly.
Nctnico, you are talking about SoCs - that is by far not the same thing. Someone who is capable of implementing a pre-made module like a Beaglebone into a product may not be capable of actually
developing one with a bare SoC (or it may not make economic sense because of low volume).
Reacting to the OPs issues, there is nothing wrong with embedding Linux in a product - it is pretty much the same as embedding any other OS, be it VxWorks or Windows CE, there is quite a bit of support and documentation for it too. It is the same as with everything else - either you have the money to pay for the work to be done (hire an engineer, subcontract it, etc) or you must have the time to learn to do it yourself. Not willing to learn and wanting to have things cheap/for free is pretty much a killer combo for any project
If you need the high-level capabilities provided by the OS, by all means, go for it. However, then you better design your own board around some SoC too, depending on an external vendor for the CPU modules is probably not a good strategy long term. On the other hand, if your design can be handled by an MCU, then using Linux is likely not going to bring you many benefits, only extra complexity you don't really need as you aren't using the capabilities of the high level OS anyway (multithreading/processing, UI, networking, USB support, SATA support, etc.)
