yesterday I bought a pair of tulip 1000BASE-T Twisted-pair cabling Cat-6
and a pair of fiber optic Gigabit Ethernet 1000BASE-SX over multi-mode fiber
made by Phobos using a 770 to 860 nanometer, near infrared light wavelength
every node in Cerberus comes with a limited bandwidth due to the PCI
which is 32 bit (instead of 64 bit) and 32 Mhz (instead of 66 Mhz)
32 MHz × 32 bits × 1 byte / 8 bits = 128 Mbyte/s
therefore the bandwidth is strictly close to the bandwidth of the controller
with is close to 100Mbyte/sec
fiber optic Gigabit cards are faster than Twisted-pair when they come
with larger ethernet buffer along with smarter controller aboard
and this is the lucky case, 10% faster, if you buy cards from Phobos
therefore I can reduce the bottleneck of the 100Base-T cards
(Digital is the best producer, in this case) currently used in Cerberus
This standard is highly popular for intra-building links in large office buildings,
co-location facilities and carrier-neutral Internet exchanges.
In my case it's used only for its property of being 10% faster (as controller)
than every 1000Base-T I have ever tried.
I will used a couple of them inside the main nodes of cerberus, node0 and node2
giving them the possibility to "resync" each to the other
externally, to connect Cerberus to the home-lan …well I don't have Cat5 cables
in my house, therefore I am limited to Ethernet 100Base-T (~10Mbyte/s)
but it's Cat6 in the white room where Cerberus silently works,
therefore NFS and CIFS rock, actually faster than a FSCK
it's a shame that laptops don't come with a fiber optic plug
