Seems like the trigger mechanism is just a heater, so yes, applying sufficient voltage should cause them to actuate. However, since it's a thermal mechanism, initial temperature will affect actuation time, so if that's important you may want to apply a lower power level to preheat the mechanism, or regulate the power input according to system temperature. That's a bit more complicated, especially if you want to ensure that a glitch will not result in premature triggering. . .
