Author Topic: I am unable to use C Macro related to peripherals of PIC32mx. [Solved]  (Read 1067 times)
Offline abrarbaigTopic starter
  • Country: sa
I am unable to use C Macro related to peripherals of PIC32mx. I am using xc32 v1.43 . I use #include<plib.h> as  mentioned in the literature. I am using MPLabXIDE v 4.01
« Last Edit: March 21, 2018, 07:38:16 pm by abrarbaig »
  • Country: sa
Re: I am unable to use C Macro related to peripherals of PIC32mx.
« Reply #2 on: March 21, 2018, 07:34:23 pm »
Thanks . I have downloaded the additional software.
Offline SiliconWizard
No problem.
Microchip is making the "peripheral libraries" deprecated, this is why they don't include that as standard with their compilers anymore. They will probably remove them altogether one day or another, so I would suggest you start working on doing without them, either by using Harmony (*cough cough*, I wouldn't), or directly control the peripherals by their registers, it's not that difficult, and the peripheral libraries source code can get you started.
  • Country: sa
Thanks for your suggestions. I used to control SFR's directly but I just wanted to try macros as well.
