Author Topic: I have been in the mood of designing development boards...  (Read 1995 times)
Offline technixTopic starter
  • Country: cn
  • From Shanghai With Love
    • My Untitled Blog
« on: November 08, 2018, 03:11:36 am »
Last night while submitting LSOF boards for a next batch, I decided to cook up yet another dev kit. This time it is SiLabs C8051F330.
That board is designed in the form factor of a 0.6in DIP-18 size. Comes with onboard USB-serial and a CMSIS SWD connector for C2 debugging. Due to the size, it has been quite a squeeze to fit everything in.
I have been in the mood cooking up dev kits recently: LPC2103+DAP42 SushiBits ARM Classic Pro, STM32L4+XC2C32A SushiBits Duplex Mini, and this C8051F330 one M1DKv1-C8F330
« Last Edit: November 08, 2018, 03:13:59 am by technix »
Offline Mr. Scram
  • Display aficionado
Re: I have been in the mood of designing development boards...
« Reply #1 on: November 08, 2018, 05:47:50 pm »
Are you actually trying to market these boards or are you mostly in it for the exercise itself?
  • Country: cn
    • My Untitled Blog
« Reply #2 on: November 08, 2018, 06:31:24 pm »
SushiBits ARM Classic Pro is being marketed - currently available on my Tindie store.
SushiBits Duplex Mini is currently a POC.
M1DKv1-C8F330 is not determined.
Offline Mr. Scram
« Reply #3 on: November 08, 2018, 06:39:31 pm »
In that case, can you perhaps tell us a bit more about what gap in the market you saw that needed filling and which role each of your boards plays in that?
  • Country: cn
    • My Untitled Blog
« Reply #4 on: November 08, 2018, 07:14:29 pm »
SushiBits ARM Classic Pro is yet another Arduino Uno compatible board, but this time it is based on ARM7TDMI core. "Pro" in the name means it has an onboard CMSIS-DAP based debugger.
SushiBits Duplex Mini is a multi-POC for both some concepts I have in mind and some aspects of another project. Following some discussion I do see that project being revised into a MCU + FPGA + QSPI board in Arduino Uno form factor.
M1DKv1-C8F330 is an evaluation board for C8051F330, and also a C2-SWD interfacing POC (I am using the ARM CMSIS debug connector for a lot of things, and since at least on J-Link v9 SiLabs C2 interface also uses SWD format I am curious to try.) Currently it is essentially a breakout board with onboard USB serial and power regulator.
Offline chickenHeadKnob
« Reply #5 on: November 09, 2018, 03:06:50 am »
Mr. Scram was prodding you gently to consider  the end market appeal of your dev boards.I don't want to be harsh I simply don't see them as being particularly compelling.
The following users thanked this post: Mr. Scram
  • Country: cn
    • My Untitled Blog
« Reply #6 on: November 09, 2018, 03:54:44 am »
Since two out of three are more POC than anything...
None of them are intended for end market purposes anyway, all of them intended for developers.
Offline SiliconWizard
« Reply #7 on: November 09, 2018, 03:42:26 pm »
Are developers not an end-market for dev boards? ;D
  • Country: cn
    • My Untitled Blog
« Reply #8 on: November 10, 2018, 07:58:08 am »
Being POC, I don't see selling them to anyone.
« Reply #9 on: November 10, 2018, 11:57:04 pm »
Oh ok, so there is no market to talk about then! ;D
