Author Topic: I have problems to drive a 2.8 TF via SPI  (Read 1804 times)
Offline ale500Topic starter
« on: October 17, 2015, 08:17:35 am »
I have a 2.8" TFT that I bough some years ago. Here is a photo of it. It should have a ILI9341 or similar controller (Maybe a ILI9325, it shouldn't need an A0 line). The thing is I want to drive it via SPI, according to the docu of this controller I need an Address (command/data) line... if I believe the writings on the silkscreen... then I don't need it... On the silkscreen is a "www.powermcu.com" website that at some point may have had such a display in store or so.
Any help/ideas would be appreciated !
Edit: I forgot the picture :/
« Last Edit: October 17, 2015, 09:40:08 am by ale500 »
Offline FreddyVictor
Re: I have problems to drive a 2.8 TF via SPI
« Reply #1 on: October 17, 2015, 03:44:30 pm »
all the displays I have have the A0 (or D/C : Data/Command mode) pin
a quick search gives this similar display - appears to be some working code at the bottom of the page which may help ?
Offline unitedatoms
« Reply #2 on: October 17, 2015, 04:40:42 pm »
This is my SPI TFT blog article. I hope you can find useful bits in my code
http://www.unitedatoms.com/blog/pixel-herding-with-ili9341-on-quark/
Interested in all design related projects no matter how simple, or complicated, slow going or fast, failures or successes
Offline obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« Reply #3 on: October 17, 2015, 05:12:26 pm »
Also sometimes called RS as in Register Select. Look right on the double row header...
Arduino Template Library | Zalt Z80 Computer
Wrong code should not compile!
« Reply #4 on: October 18, 2015, 09:26:12 am »
I saw that pin on the PCB, what is a bit disturbing is the silkscreen legend... oh well, it is then as I thought. I'll try the code for both controllers and see which one works...
