Quick question for those of you familiar with Microsemi's IGLOO nano FPGA chips:
I've noticed that these chips offer two voltage supply specifications: V2 spec, which allows supply voltages between 1.2V and 1.5V, and V5 spec, which allows 1.5V supply voltage only.
Now to my question: What advantages, if any, does the V5 spec'ed parts have over the V2? Particularly from a functional/performance point of view? The V5s seem to be slightly less expensive than the V2s (even though not by much), which could count in its favor for large scale production.
I assume that the V5s are merely V2s that have been scrapped (i.e., failed testing). Would anyone be able to confirm this for me? If this is not the case, what are the differences in terms of fabrication?
Finally, if I am correct is assuming that the V5s are scrapped V2s, would it be possible for the V2 part to deteriorate over time, especially when operated in harsh environments (ionizing radiation in particular), to also exhibit reduced functionality when powered from 1.2V?
